AndrewDouglasBird
The front corners of my garage have sank down several inches, causing a large gap under the garage door on each side.
My original plan was to cut a wedge of wood to attach to the bottom of the door to fill the gap, but when I tried that today, I found out the block of wood hits the top of the door opening.
So now I've decided the only option is to fill the drop in where the sunken part is and taper it back to where it is flat. I didn't want to have a bump like this on the floor, but there isn't any other option.
What should I use as a filler? The thickest part will be around 2" thick. I've already made some wood forms around the area I want to fill, I just need to know what to pour in it.
Thanks.
Thanks.
