wolf_from_wv
This is a 1997 Ford F250 with 7.3L engine and extended cab. I'm trying to help someone fix a broken shaft. It appears to have a Dana 50 front axle. The hubs are manual.
The problem is that the diameter of the 3/4 drive 2 3/4" socket he had was too big to take the nut loose. I don't remember if the nut had rounded corners - I found a 2 3/4" rounded corner socket http://www.toolsource.com/wheel-bearing-locknut-socket-t95t-1197-rounded-p-108029.html .
I found a link to http://www.ford-trucks.com/forums/1055837-d50-spindle-nut-socket.html that said the 6 point socket was for the automatic hubs, and the 4 pin socket was for the manual hubs. Warn has a listing on their page saying the same thing http://warn.iwebcat.com/_Members/lo...nOEM=1&hdnUniv=0&hdnMM=-1&hdnAPFlag=&hdnWN=1& " Manual Hub Spindle Nut Kit; 30 Spline; Replacing Automatic 3 Hole Cap w/Manual; Use Correct Spindle Nut Kit; "...
I guess I'll have to look at it again to see...
