NuthinFancy
About to start building a detached 20 x 30 workshop on a poured slab and thinking about insulating the concrete as I intend to heat/cool the building with a mini-split type unit. No in-floor heating here.
Naturally, the walls and ceiling will be well insulated.
After some research, my initial thought is to go with 2" XPS (plus 6 mil plastic) under the slab and on the outside of the perimeter, which will have a 9" curb wall, mostly above grade.
First question that came to mind is: how do you protect the XPS that's above grade on the perimeter?
The ground around the building will be either stone or wood mulch, so no grass cutting or trimming to worry about, but paint alone seems inadequate as well as high-maintenance.
Suggestions?
Suggestions?
