1/16" Diameter Wire for a Specialty Tool
gotwheels
I have a specialty tool that that I use that is similar to an awl, but has ~ 5/8" long straight tip, 1/16" in diameter. I have used the shank of a 1/16" drill bit for this tool. In the application there can be some slight prying and the drill bit is so hard and fragile that it snaps, with any bending pressure.
Would someone recommend a wire (1/16" diameter) that has stiffness but is malleable enough to bend a little before breaking. I am not familiar with wire types (maybe a type of welding rod?) and hope someone can help.
Thanks in advance for assistance.
OccupantRJ
Eastern North Carolina
.062 music wire. It is spring steel. I will look to see if I have any that diameter, if I can remember to do so tomorrow. You could cut a straight section out of a tension spring that has long hooked ends.
hunter1151
Kansas
Spring steel.............or sharpen the other end of the drill bit.........it is softer on the shank.
kbs2244
Look for air plane "safety wire"
They use it to keep bolts from getting loose.
Standard procedure is to twist into a two wire rope.
rlitman
Long Island
Tig Master
Where it snows
This is way more brittle than a drill bit.
This is dead soft and bendable, as it's designed to be twisted.
Any hobby shop will have music wire. THIS is by far the best choice for this use.
I have been using small tungsten's 1" long in a pin vise for years and they are quite useful and have been tig welding for 30 years.Yes you can break it but as a scribe they work very well.
T
G
gotwheels
Thanks to all for the suggestions, I will pursue the music wire & the SS TIG filler wire. This site is great with information sharing & the knowledge!
