entirely WTF moments in tools breaking/bending
AmishFury
so last week i was on a junk yard run looking for a seat and an axle shaft
while trying to liberate a cotter pin from an axle shaft i bent my channellock needle nose
a cotter pin that should have broken long before bending my pliers did this
mrvm
PA
One good smack on an anvil with a smith's hammer will fix that right up. Use a stronger non-needle nose or make use of the cheap HF versions
mech-tech
Don't have a pic of it, but was using a regular clear handle 1/4" craftsman screwdriver to pop off a bearing cover on a wheel. Was tapping the end of the handle with a hammer to get it under the metal tin cap when I felt it finally going...but to my surprise what was going was the metal shaft of the screwdriver sinking further and further into the plastic handle until there was barely any of it stick out out at which point I tried another craftsman screwdriver and it worked on the first hit. It was almost as if that screwdriver handle was filled with jello. Never had that happen again with any other screwdriver, both cheap or pricey.
T45
might be handy for the junkyard
and stronger than needle nose
