3m Panel Bond Adhesive instead of welding
Whiskeymike
Austin, TX
Anyone use 3m Panel Bond Adhesive instead of welding? I understand that it can be stronger than welding. Is it ever used when the steel is painted? Or do the automotive companies that use it, apply it when it's bare metal panels and then paint afterwards?
I'm looking to affix plasma cut steel signs and would prefer to not weld it due to warping thin steel and I'd also like to paint it first before affixing different layers together.
Any recommendations on brands? 3m seems to provide the best stuff, but it's pricey so if there's a lower cost alternative. My stuff is not structural, but I don't want it to fall apart.
Bill Bowman
Metro Chicago
I've used a lot of the 3m stuff, in fact, several years ago, I did a seminar to show the 3m rep how to properly use it. Basically, you want clean sanded steel on both surfaces. Spread a thin coat on each part, covering the entire sanded area, then a small bead, or squish/ooze bead. Clamp it together and clean off any excess that has worked it's way out the edge, with lacquer thinner. Easy peasey. Just, as you mentioned, NO structural situations.
HD FLHX
Central Iowa
I've been using 3m's panel bonding adhesive since the late 90's. Excellent product. When used in its intended purpose it needs to be used on bare steel. Check out 3m 08217 universal adhesive it maybe suited better for your application
Radartom1
Alabama
not sure how big of a sign your building but I have done the same double layer plasma stuff with the 3m double sided molding tape, works like a champ.
W
Whiskeymike
Austin, TX
This sign is 4x3 and probably 3 layers. I've heard a lot about the 3m tapes and ordered a roll, but just nervous of it separating after the fact.
I'll check out the 3m Universal and Evercoat as well.
Thanks guys
kerrynzl
Tauranga, New Zealand
I use a Bostik variety .[Simson ISR 70-03] it is cheap
It is only as strong as the surface you adhere it to, so clean bare metal is best.
I've done a few tests to destruction with it.
It will pull hot dip galvanising or powder coating off the surface before it lets go.
I did a thread here on a trailer build where I used it on the deck
kbs2244
Most people do not realize that their roof top luggage racks are glued on.
And that jets are often glued together.
theoldwizard1
SE MI
I've used a lot of the 3m stuff, in fact, several years ago, I did a seminar to show the 3m rep how to properly use it. Basically, you want clean sanded steel on both surfaces. ...
Clean, clean, Super clean !
Do you recommend any kind of "surface prep"/etchant ? (Folks doing aluminum sweat by Rustoleum "self-etching" primer.)
countryroad82
Kentucky
I've been using it a lot as of late. The big thing is it has to be clean metal on both panels or your asking for a failure point.
sberry
Brethren, Michigan
You are asking about a product,,, a different thing than the application or the intent.
Signs are a bit different than auto body, double stick tape to hold the pieces together while a gob of silicone sets up is the trick. Economical is good here as is practical.
Daveo
Panel bond shouldnt be used on a surface that will show. I mean like a quarter sail panel, I seen a couple shops do it and it always comes back with a "ghost" line. Meaning you can always see where the panel was glued on.
LIGOOMBA
Matthews NC
I work on a sprint cup team and we use that stuff like nuts.No issues ever.We use Lord Fusor though.For metal signs I would use the 3M 8115 that's what I have used to put door skins on.I would grind the metal with some 50 grit roloc pads glue/clamp .
theoldwizard1
SE MI
They use a fair amount of adhesive on the aluminum body F150.
Where they can get away with (cosmetic reasons) the use self drilling blind rivet. Fast (adhesives do take time to cure) and inexpensive, especially when installed by robot.
RivennHewn
PNW
We've had several signs made, in different thickness up to 1/8", and installed them with VHB tape.
There is a large selection of widths and thicknesses.
We usually just wipe the mating surfaces with acetone.
sberry
Brethren, Michigan
Mike, I may be off here but asking if these products are good is a separate issue from is this the right product for me. Its likely you ant a simple adhesive sealant, Lexel or in many cases simple silicone on super sale when you can get a few tubes and a simple caulk gun.
Its not likely you need an expensive precision system designed for auto body finish on top etc.
kerrynzl
Don't use silicone , use a urethane adhesives
They're paintable and come in Caulking tubes.
sberry
Brethren, Michigan
Sure, a urethane is great and convenient but the sign industry uses a lot of common caulk too.
My point is,,,,,, the question is like,,, what is the best auto paint, turns out He is whitewashing a fence.
He asked about something which I suspect isn't the right type of product for him
