Saturday, 02.27.2016:
As we have planned we continued with the corrugated sheet aluminum. Reinhard has finished last week the tool and made an impromptu test with two screw clamps. It works.
View media item 58514The tool before bringing it to our new workshop.
View media item 58515The two parts of the corrugation tool were installed to the front of our big press.
View media item 58516Here you could see it in detail. On the right side we installed a type of counter bearing, made from planks and a piece of rubber to prevent the press from unilateral erosion.
View media item 58517Four grub screws to install each part without drilling a hole to the press.
The making of a corrugated sheet:
View media item 58518After the first pressing. We started at the middle of the sheet to reduce the mistake. If you have only 1mm deviation at every step it is better to work in two directions.
View media item 58519Before the second pressing. We have to turn the sheet for every step. So the last valley is then a back.
View media item 58520After the second pressing.
View media item 58521Sample of our corrugated aluminum. Everything is homogeneous, even the remaining flat parts of the sheet. In the background you see centimeter.
View media item 58522For comparsion: a normal corrugated iron sheet and our handmade one.
View media item 58523Here is a former cabinet door, while making. In the background a wing part of a JUNKERS JU-52. Our corrugation is very similar to the old aircraft – enough for our purpose.
View media item 58524Testing the stability. Both are AlMg3, 0.6mm. On the left a 200g, on the right a 1000g hammer. Ok, you need a little bit more square centimeter sheet metal for the corrugations. But the result is much stronger.
View media item 58525A first view how the corrugated sheet aluminum will look as a cabinet door. But we have to solve a lot of problems to fix that new material to our until now used cabinet parts. Most of the rivet holes are at the wrong place.
The other cabinet with the HUEY doors:
View media item 58526Drilling the holes at the door skin with the help of a template.
View media item 58527Both fitted and drilled door skins.
By the way, we published 855 pics in total in the last three years. That means I have only 145 pics for the future. That will be a problem when I try to show the next steps in detail. Any idea?
