bigjon
Concrete & shed (9m X 7m X 2.7m high) went down in June 2015 but since the block is in a new area and full of dust decided to hold off putting down a coating. Now that we've moved in and other houses are around I took the plunge and purchased my coating system to apply this Easter long weekend. In my previous place I had good success with Sigma Coatings which is now owned by PPG. Went with their Sigmacover 456 (colour is Merino, AS Y56), Rust-oleum RockSolid tan flakes (from the hardware store) & Amershield Clear as the final clear coat. Spent yesterday all day clearing out shed followed by acid etching floor. Had to do it twice as it was power troweled and extremely smooth. I only stored some landscaping equipment in there so the floor was only dirty from mud, etc., no oil stains.
After etching and cleaned:
Primer coating products:
Primer coat (Thinners @ 10%) went down this afternoon. Unfortunately the concrete soaked it up and had to use my second coat supply which means I don't have enough to finish this weekend.
Primer coat:
Will have to wait till Tuesday when the paint supply store opens on Tuesday due to Easter weekend.
Plan on completing 2nd coat Tuesday afternoon followed by the flakes. Going to put the flakes on high as I like the look. Probably do 5 boxes for the 63sqm. I'm tossing up whether to put 1 or 2 clear coats as the tech data sheet only has 1.
Below are the data sheets:
http://www.industrialsupplies.com.au/pdf/Sigmacover_456_DS.pdf
http://www.industrialsupplies.com.au/pdf/0001Amershield_PDS_March_08.pdf
http://www.rustoleum.com/product-ca...ksolid/garage-floor-kits/decorative-chips-new
Cheers,
Jon
Primer coat:
Cheers,
Jon
