Davefr, the Proto ratchet I showed in the closeup above shows a much beefier set-up than the example you posted. Would mine be older than the one you described, or newer?
Maui
My guess is yours is much older!!
Maui
In 1/2" drive, my favorite ratchets are the ooooold Herbrand S-10 and the Thorsen #77 open gear.
nothing glamorous, but very tough.I actually did mention the Proto/Plomb 5449. But as ones to avoid.
Proto used a thin sheet metal selector lever and it's only held onto the outer shaft of the internal pawl cam by being peened on. It's very common for it to loosen up and when it does you need to push the lever beyond it's range of movement to disengage he pawl. (assuming it hasn't already fallen off and got lost).
It's the worst (wimpiest) selector design of any ratchet I've ever seen. You can't always re-peen it because there's often not enough metal to re-peen.
I think Proto improved the selector in the current model.
The only aspect preventing me from buying a vintage ratchet is lower tooth count. If anyone has a particular suggestion, feel free to let me know, thanks![]()
four.cycle;5613334{/quote said:I think the US-made Thorsen stuff is grossly underrated, for reasons which aren't exactly clear to me. I have several of the little 1/4" drive ratchets and a couple 3/8", but no 1/2" models. Guess I'll have to keep an eye out for one.
Open gear Thorsens = The AK-47 of ratchets...nothing glamorous, but very tough.
I just picked up this box and found it to be full of old ratchets
My 32ish year old Master Mechanic Taiwan ratchet next to my Dads 1975 S-K.
I was too poor to afford a Craftsman starter set @ $59.99, so I picked up the MM in all three sizes, each with their own red tin box for $39.99. No deeps or long extensions, but I made do for several years until I added a Cman kit. It's been a very reliable ratchet and is now reasonably smooth after many years of use.
So, there are three little nuts in the picture. They were in the S-K box, and just by finding them, I know about the last thing my Dad did with it. Replaced the tail light in Mom's 1992 Buick Regal. My Dad never was one to sweat the details, if three nuts will hold, the other three go over his shoulder....
That reminds me, I have some master mechanic usa tools that were made by Easco. There are Master Mechanic USA rhft ratchets out there.
I just picked up an older Cornwell TR3 1/4 ratchet today. Nice ratchet, speaking of vintage.
But then, someone mentioned needing ratchets with fine teeth in order to work in modern engine compartments...
Now I get it.
I pop the hood on my cars and wonder how in the heck do I work on this sucker??!!
My hands are too big!
