Wrenches with "flank drive plus" technology
bmwpowere36m3
Maybe it would be more helpful, if the OP stated his budget… Unless I missed something. I think what he wants to spend on wrenches, rules out a lot of the recommendations.
C
cesski
I am simply asking about other alternatives or similar offerings to Snap-On's Flank Drive Plus to educate myself... seeing that there are a lot of options out here in the US that I have never had experience with before.
Also, I just bought the Sunex.
mr.speaker
Florida
Let us know when you get those wrenches. I was looking them up on eBay and it looks like some of the V-grooves have the teeth and some don't ..Not sure what's up with that because mine definitely have the teeth and I picked them up a while back
mr.speaker
Florida
See what I mean ? Both V-groove , but one has the teeth and the other doesn't
I don't know what's up with that, same model number listed but obviously different
C
cesski
Yikes! Now you got me worried! :/
Sent from my VS986 using Tapatalk
jhnlngn
There are a few differences. Snap on Flank Drive Plus open ends use teeth. Williams uses notches. I think the teeth grip better. The Snap on FDP wrench is thinner and lighter. The Williams is a little heavier but, avoids the knife edge fell if leaning heavy on the wrench. Here are a few crappy pictures of a 15mm wrench. Please don't think you're getting a snap on wrench by buying the Williams cheaper. They are completely different. :beer:
Thanks for the info and pics!
Strouty
Southern Maine
One thing that no one really discusses is the damage that these "teeth" can do to hardware. If you don't care, then don't worry about it, but if you are working on something special it may be an issue. I bought a nice set of non flank drive plus 6 point wrenches to work on anything that really matters.
GSMotorrad
Yup, and how often are you guys having non-flank drive open ends slipping off stuff? In all my years, it's never once happened to me.
Yes, the flankdrive does grip better, but unnecessarily so, with a higher cost and possibly leaving dents in fasteners.
BK13
PDX, OR
Gee, does that mean I need to get TWO sets (well, actually more like eight, SAE/MM, midget, standard, standard with teeth, XL) of combo wrenches? Dang.
OutsideMachinist
Norfolk, VA
You should have two anyways for times when you cant use a socket and have to use two wrenches.
Fedwrench
Valley of the sun
I noticed that yesterday while internet browsing. I don't know if it's a matter of old stock vs. new stock but, the only pictures of sunex wrenches I could find with the modified open end with teeth were of ratcheting wrenches:dunno:
That is definitely true. I once had a customer that wouldn't allow techs to use power tools on his truck because he didn't want the fasteners scratched.:wtf: I don't think a tech really needs non slip open ends on wrenches all of the time but, they are real handy for suspension work for those instances when you can't use a boxed end.
PJNJ
Iowa
Actually three sets - one with non-slip ends, one with regular, and one to cut up and bend to make special or one-time use wrenches.
The more the merrier.:bounce:
:beer:
OutsideMachinist
Norfolk, VA
:beer:
Well yeah. I just meant two sets of combination wrenches. Doesn't include the ratchet, flare nut, stubby, cutoff/specialty, obstruction, slugging/striking etc you may need. As others have said I have only seen the sunnex ratcheting wrenches having the modified open ends. May want to research that a bit before anyone gets the regular v open ends.
Clemson13
I hope no one runs into issues with that!
I have no idea if only the ratcheting ones have the teeth as all I have are the ratcheting w/teeth.
As far as marring fasteners, how often do you really care if non visible fasteners get some scuffs on them?
Strouty
Southern Maine
I have flank drive plus xl wrenches, proto ASD spline ratcheting wrenches, wright grip wrenches, snap on open/flare combo wrenches, snap on six point non plus open ends, gear wrench twisted flex wrenches, older craftsman pro stubby wrenches, and then lots of specialty and weird wrenches. All of these are in metric and SAE. After 1 1/4" I only have SAE. I use my proto and wright grips the most.
I will say that after about 3/4" the ASD/flank drive plus really doesn't matter.
As far as people asking about open end wrenches slipping on fasteners, well in the rust belt areas it is more common, especially with less expensive wrenches.
Clemson13
Im allowed to be jealous right??
:bowdown:
C
cesski
Just got confirmation that the non-ratcheting version does not have the "anti-slip". Bummer. Canceled on them and got Gearwrenches for cheaper instead.
lilxtra
Bulls Gap,Tn.
Ok Strouty, what's with those two "piles" in the middle, let's get with the program and get those organized!!!
J/K- great looking setup!!
bmwpowere36m3
To be honest, I rarely see any "damage"... no more than any other tool would leave behind on a stuck fastener. To me its more important to be able to remove fasteners without rounding them off, then some marks a left behind. Fasteners can be replaced... using drills, extractors, etc. only causes head-aches.
Then again, I usually only find myself using an open-end as a last-resort due to clearance or situations like jam-nuts... and I don't work on chrome polishers :D
jrobb316
WI
This is my metric wrench drawer. The only flank drive plus wrenches I have are the regular length snapons. The proto USA ratcheting wrenches are ASD. I like that better because it's more subtile than the teeth. I find the teeth hard to get on and remove from fasteners. Im not a fan, I think it's a gimick. The rest of the stuff is craftsman USA stubbies and deep offsets, gearwrench Taiwan S-shaped, half moon, and 0 offsets up to 25mm, sk flare nut wrenches, Allen 20 - 24, 27mm large wrenches, snap on short, regular, long, and double box 0 offsets, and a set of mini wrenches in a pouch.
C
cesski
@barrybeefburger
C
cesski
Thanks Sprintman. I thought there would be someone else as he doesn't have any SAE tools in stock.
exmaxima1
Midwest
What other brands has this "anti-slip" technology in their wrenches? So far, these are what I've discovered...
Wright Tool's WrightGrip
Snap-On FD+
Proto's ASD
Mac's Knuckle Saver
Matco’s Opti-Torque Pro
I ask because I'm in the market to buy a set of combination wrenches, new or used.
Craftsman Max Axess long pattern combo wrenches have similar flank drive box and notched open ends
chris142
apple valley,ca
I gave the Snappy ones. They work great for a damaged nut or somewhere that you cant get a boxed end on. They absolutely **** for normal use. They damage the bolt and are hard to get on and off it quickly.
pennsylvaniaboy
please let us know how the sunex work out?
pennsylvaniaboy
I canceled my order. The non-ratcheting version do not have the "anti-slip" notches/teeth. I ended up going with Gearwrench.
dang......i was super hopeful at that price point....
I take it the only USA options for this are Williams, Wright, and Snap-on?
