impactsocket
- Joined
- Jan 9, 2014
- Messages
- 769
What is the best budget battery analyzer / tester? What is the best for under $100?
Solar BA9
The BA9 tests 12 Volt batteries with an operating range of 40-1200 CCA and is optimized to test four distinct battery types: Conventional Flooded Acid, AGM Flat Plate, AGM Spiral Wound and Gel Cell batteries. The tester provides accurate assessment of both charged and discharged batteries (down to 7 Volts) and features a variety of safety features, including reverse polarity and over-voltage protection, to make testing safer for the operator and equipment being tested.
Harbor Freight Cen-Tech
Con: The unit has a frustrating interface, and it is hard to get the digits to advance. Also, when you connect to the battery, there are noticeable small sparks at the terminals, since it powers up immediately. Not good. We all know batteries produce hydrogen when charging.
Ctek
Con: Only gives the state of the battery as good, recharge and retest, or bad. The Solar BA9, which is in the same price range, gives much more information about the condition, charge, and health of the battery.
OTC 3183 Digital Battery Tester
Con: Bad review from Amazon: I had to send this back. It would not work on any kind of battery I tried it on. I called the manufacturer and they said it was not reliable for testing AGM or any deep cycle marine battery. It even gave me a false test on a known good battery that I was using. It would only test ok on that battery if I changed the setting to below 32 degree's when the temp in my garage was at 60.
Midtronics PBT300
Question: Is the Midtronics PBT300 better than the sub $100 battery analyzers???
Solar BA9
Ctek
Midtronics PBT300
