Another lift question
Redwolf947
South East WI
I'm looking at lifts. I have a 2003 F250 supercab 4x4 with 5.4 and a 2012 mustang 3.7 v6 coupe. I need a lift that can lift both of these. I'd like to keep the price below $2500. I have some time hope to buy something by fall.
I like the in floor or surface mount full-rise scissor lifts but they seem to be pricey. I guess I could use a mid-rise? I have used 2 post lifts before but never really liked working under them. This leaves me with 4 post lifts. I'm looking to do regular maintenance. like a clutch on the mustang or rear diff on the truck oil/fluid changes, brakes etc... I've only used a 4 post once at a friends shop and loved it.
Ive looked up and took a few dimensions of these vehicles and determined they are pretty close in width the mustang @ 73.9" and the truck at 79.9" so 6" not too bad. The curb weight is 3447lbs for mustang and 5601lbs for the F250. Makes me think a 7k lift or better. I was looking at direct lifts, auto lifts, dannmar, atlas probably a few others.
I noticed the outside widths of the actual platforms on most of the 8k and even the 12k lifts of different brands was 80" max? I see the drive thru distance was greater or the between posts was pretty big but this width of 80" I don't see wider? I don't think I want to try to square up on a lift with .1 inches to spare.:headscrat
Am I missing something?
Does anyone else have this combo of vehicles and a 4 post?? OR does someone have a 1999-2007 f250 on a 4 post so I can see the clearance?
R
Redwolf947
South East WI
Hurm didn't phrase it right??... I guess I'm asking whats the dimension from outside edge to outside edge of your runways on your 4 post?? Also is 8k the correct weight capacity for my truck according to weight specified before. humr I guess I don't know how to ask :(
R
Redwolf947
South East WI
So doing some more research I see bendpack has a "wide" setting do all lifts have this? I don't see it stated? Thanks??
tfalk
Somerset NJ
If you have the ceiling height, you might want to go with something like this:
http://www.gregsmithequipment.com/Atlas-409-HP-9-000-LB-Four-Post-Lift
My friend has one and his F250 2wd fits underneath with a mustang on top. They had to box out the ceiling for the roof of the car since our garages have an 11' 8" ceiling.... If your ceiling is over 12' 6", you should be good... Not sure what the roof height is on your F250 but I'm thinking it might be taller than 6' 4"... IN that case, this one might work, that's the one I was going to order until the town shot down my garage...
http://www.gregsmithequipment.com/Atlas-Garage-Pro-9-000
408sbc
If you rather not do the concrete rework to surface install (assuming an existing structure) and wanted the flexibility of being able to move unit + could get by with a mid-rise.....check out the Atlas Kwik Bay 7000.
R
Redwolf947
South East WI
I looked at this but I wont get enough lift for the Stang. I know I'll be limited with ceiling height for the truck. I want what lift I can get for the Stang..
Thanks for taking some time to link thoes. I wish I had the height but I'm stuck with 10'-8". I looked at those lifts both nice setups, I really like the 4 posters.
R
Redwolf947
South East WI
My first reason to buy a 4 post lift was so I could roll it out to the drive for the truck and work in the garage with the car. My garage being 22'x22' and the new ceiling height once I'm done of 10'-8". I can't see loosing the real estate with the 4 post. :mad:
I Guess I'm looking for a scissor lift? Something like the Atlas Slp-7K Full Rise Scissor! This can lift the truck and the car in the garage. I'd need the Lift Support Bars for the truck too so that's another $350. Total with bars is $3,945 from Greg Smith Equipment.
I can mount this to the floor for now. I can cut the concrete to mount it sub surface later. Its a lot more than I want to spend tho. Anyone have promo codes for Greg Smith?
Like I said in my first post I have time but trying to plan ahead for whats best for my garage.
Any other ideas or suggestions.
jfitz
Eastern Ontario, Canada
I have just a little bigger garage, 24 x 24 and I bought a Bendpak HD9-XW with the castor kit and an RJ45 rolling centre jack. I bought this because it would lift my 08 Dodge Megacab and only had to fold one mirror in when driving on. It also has one runway that is adjustable for narrower vehicles. It is also about one foot narrower in width than other 9k lifts so I could fit my other vehicles between the garage door frame and the right rear post of the lift to get into the garage. I bought it in June 2015. So far no complaints
pmiranda
Austin, TX
Measure your outside tire widths. Even a dually will be under 80".
WhiffySpark
Every truck I've pulled on drive ons had about 2-3 inches on each side. More on right side probably. I always pull them on with the right front tire about 2 inches from edge
stngfever
West Michigan
Seems I may have the similar vehicles to use as reference, however, a 2 post not 4.
One other difference is my 12'ceilings.
I have 07 Mustangs and just purchased a 2006 F-150 supercab 4x4 that looks to come in at ~5400 lbs. I'll put it on my 1987 Weaver 2 post 7k lift in a day or 2 and report back some details. My weaver posts are ~9.5' tall with a floor plate.
R
Redwolf947
South East WI
Thank you for that. If I can't find a reasonable priced full rise scissor this will probably be the route I go. Mind if I ask what the over all cost was with the castor kit and an RJ45 rolling center jack?
R
Redwolf947
South East WI
What kind of lifts were you driving on? I could see commercial and/or the higher weight capacity lifts being wider.
R
Redwolf947
South East WI
Cool thank you. I look forward to it.
WhiffySpark
10-18k
The only wider ones I've used are for class 8 trucks. I could align a school bus on it and still have 5 feet in front of the lift lol
pmiranda
Austin, TX
I didn't just go with what the net said about my truck width I did physically measured it. With the tires that are on it now I'm at 79.5" to 80".
Doh! I'll just STFU then.
FWIW, Even Bendpak's 7000lb lift has a wide option that gets to 82". Their 14K's go to 91"
R
Redwolf947
South East WI
That is correct. If I cant find the full rise scissor lift I want for a reasonable price I'm probably going to go with that wide option Bendpak.
zkdiesel
chicagoland cornfields
It's no problem if tire does stick off lift on one side a inch or so if you don't get centered. Watch the amateurs at work do it daily without mishap
