ex-x-fire
I try turning them right after I quench them, the water drives the heat deeper inside, so I'm told.
Huh?the water drives the heat deeper inside, so I'm told.
Huh?
This all depends on whether you're trying to shrink a bolt or expand a nut...
Different solutions are for different problems. Go try to get a stud out of an aluminum engine block with a torch, and see how that works out for you.![]()
Can someone explain the use of wax to me? Never heard of that...
TIA
I have little faith in chemicals, and a lot of positive experience with heat.Heat/cool breaks the corrosion between the steel and aluminum. A large part of the reason that welding a nut to a broken off stud is so effective is the extreme heat from the weld.
FWIW: I have zero positive results using wax.
Maybe I'm doing it wrong, but I just end up with a stuck fastener, which is now surrounded by melted wax.
and I just used a propane torch.
I tried that wax trick.... is that some special wax used ? it just vaporized when I tries to apply it on the hot Nuts, with a lot of waxy smell all over the air, nothing in the threads at all and I just used a propane torch.
