Best Deal on a medium duty work bench
chruler
Vermont
I am setting up a new guitar repair shop at my place and need a decent work bench to do repairs on.
It doesn't need to be heavy duty, but does need a sturdy set of legs so it doesn't wobble back and forth during several of the repair operations I perform.
I have looked at a lot of Harbor Freight type benches and they're pretty wobbly.
Any suggestions?
30" wide x 60 or 72
jimgood
Marshall, VA
Are you wanting a bench that will be free standing or will it be against a wall? If against a wall, the wobbly benches are actually fine if you put a couple of screws through the rear supports into a stud or fire block.
WWShop
MN
Build your own and get the exact size and strength that you need.
BillK
Beautiful Southern Maryland
You might want to look at some of the woodworking supply houses. I would think those types of benches might be better for what you are doing. Try Rockler for starters.
TonkaJoe
Southern ON, Canada
http://newageproducts.com/workbenches/
Check these guys out, I have 2 of the 6' butcher block top version.. one in my shop with a vise and 2x2 steel plate mounted on top for heavier work. And another in my basement shop aside from my actual workbench for cleaning my guns etc. I also have one of the cabinetry sets to match. No complaints here!
theoldwizard1
SE MI
Hollow core door on top of two rollaway base cabinets, with or without wheels.
Good suggestion with a SOLID wood door ! Or make your own top by taking a bunch of 2x4, clamping them together and then sanding them smooth and level. Unclamp and then cut every other one into about 4" long spacer blocks. Glue and screw.
Attach Masonite or possibly lauan with flat head screws so that it can be replaced.
You need to add some level feet or just 2x4 PT to raise the height of your bench to a comfortable height and shim it for level.
Fill the bottom drawers with very heavy material. Use bags or small boxes of gravel if you don't have anything else. Weight = good solid feel !
MushCreek
Upstate South Carolina
I build my own, interestingly from a design by a guitar builder! The legs consist of two pieces of 1/2" plywood, about 8" wide at the top, tapering down to 4" at the bottom. Glue and screw a 2X2 in the corner to join the two pieces of plywood together. Make a top framework of 2X4's, and a middle framework as well. Glue and screw everything together, and use a solid core door for a top. I've bought a number of expensive commercial benches, and none were as stable or strong. Make it whatever size you want, and finish it pretty, or leave it rough and ready.
C
chruler
Vermont
Thanks everyone! Great suggestions. I have been pre-occupied with taxes and a new girlfriend these past couple of weeks so progress has slowed way down.
I like the idea of using a door for a top. Hollow or solid. No going to do any real heavy work on it. Mostly guitar repairs.
NUTTSGT
Northern Central Ohio
That's what I would recommend also. One of the biggest issues with workbenches is the height. What works for one person, may not work for another. . . . standing at a 30" work bench all day would kill my back.
DC73
Lubbock TX
Build a simple base out of 2x4s, then pick up a laminate counter top at one of the big box stores.
DC
crerus75
Check out this site.
The owner is a professional luthier and built a rigid bench with a plywood top instead of maple or anything too "nice." His rationale is that he can beat it up or modify it without losing much sleep over it. I'm no luthier but I used to have a plywood-topped workbench, and it was really nice to be able to screw fixtures, clamps, stops, etc. to it when needed. Just something to consider.
ez-duzit
Marina del Rey
Tempered Masonite makes a most excellent work surface for woodworking. And is cheaply replaced when it has been used up.
ishiboo
Oshkosh, WI
You can't beat the simplicity and cost of this DIY bench. Add some levelers and you should be set. Plenty strong for guitar repair...
http://www.hammerzone.com/archives/workshop/bench/below20xl.html
http://www.rockler.com/heavy-duty-lifting-leveler
I do mine like this. The only difference is for the legs, I use two screwed into each other each making a 90 degree angle. Makes things much stronger. Also, use anything but OSB for the top.
I have a 4x8 in the barn I made the same way with 2x6's, it works AWESOME but very easy to fill up with stuff.
Ad13
BC
If using a door as a benchtop, definately go for a solid core.
C
chruler
Vermont
DC
Great idea! I like a hard laminate top. Cleans up easily. Is usually pretty flat, and I can cover it with pads or other surfaces as needed depending on the job.
DC73
Lubbock TX
That's probably one of the better ideas considering what the OP is using the workbench for.
One possible drawback to the in-stock counter tops at the big box stores is that they mostly come with an integrated back splash which makes the overall working depth only 24".
If you need more depth, they can order counter tops without the back splash in any depth you need and with various edge profiles. Another option is to make a top out of plywood and laminate it yourself. Lowe's used to stock sheets of laminate but I don't think Home Depot does.
DC
Empty Pockets
Rural New York
I bought a 30" by 60" piece of maple butcher block for the out feed table for my table saw. It rests on a set of 2x4 legs. It doubles as a work bench.
My theory was build more than you need, and it has never let me down
Empty Pockets
Rural New York
DC
Lumber yards can special order laminate for you, as well. It can be attached to the wooden base with an aerosol can or 2 of 3M contact cement
