Well today I started the slippery slope of building my dust collection piping. Started with the bandsaw as it is near the end of the branch I am buiding. Made the couplings to pair the 4" hose with the 4" PVC pipe by cutting a 13/16" slot in a 3.5" piece of PVC to join the two. Then I realized I needed to build some blast gates. So I got one built and then by that time it was the end of my day.
20160208_172508 by bjohnson388, on Flickr
I will be leaving my current dust collection in place which is the 2.25" box you see in the top of the photo. I will still use my Ridgid vac to cleanup around the shop and to pull dust collection off of the router table. After the piping for the DC is all done I will tidy up all the extension cords.
20160208_172514 by bjohnson388, on Flickr
Pieces to make a blast gate. I hot glued them in for the moment in case I want to redo them. I just found a different way of making them where one side has a coupling used that fits the 4" pipe. May try one of those. I also need to pickup some more pipe and some 45* elbows.
20160208_165529 by bjohnson388, on Flickr
20160208_170749 by bjohnson388, on Flickr
20160208_172407 by bjohnson388, on Flickr
I cut the holes in the plates on my lathe as my little drill press will not run a 4" holesaw.
20160208_162648 by bjohnson388, on Flickr
Back to the grind tomorrow, but I will work away at after work when I can.
Bret
20160208_172508 by bjohnson388, on FlickrI will be leaving my current dust collection in place which is the 2.25" box you see in the top of the photo. I will still use my Ridgid vac to cleanup around the shop and to pull dust collection off of the router table. After the piping for the DC is all done I will tidy up all the extension cords.
20160208_172514 by bjohnson388, on FlickrPieces to make a blast gate. I hot glued them in for the moment in case I want to redo them. I just found a different way of making them where one side has a coupling used that fits the 4" pipe. May try one of those. I also need to pickup some more pipe and some 45* elbows.
20160208_172407 by bjohnson388, on FlickrI cut the holes in the plates on my lathe as my little drill press will not run a 4" holesaw.
20160208_162648 by bjohnson388, on FlickrBack to the grind tomorrow, but I will work away at after work when I can.
Bret
