Hex insert strap winder
astroracer
Mid_Michigan
Simple to make... A piece of 1/8th" x 3/8th's or 1/2" wide steel. Bent in a U with a piece of 1/4" rod welded to it. Probably take 15 minutes to build one... :)
Mark
astroracer
Mid_Michigan
I doubt the hex driver is really a requirement. A piece of 1/4" diameter rod will do the same thing. Drill bits have been round forever and they work fine. This winder thing should never see enough "torque" that a round mandrel will spin in the chuck.
Makr
jayrush13
Lebanon Oregon
Makr
But the hex driver would let you put it in an impact or one of the m12 screwdriver
racingtadpole
The far side of crazy.. but sometimes Australia
Makr
Its not about torque, its about being able to use it in 4 tools instead of just 1.
Brian_WK
NE South Dakota
Wouldn't work for fastjohnny as he is looking for a all metal finished look. But why not use a cheap 1/4inch shank bit and a piece of wood or plastic dowel with a slot cut in it and drill a hole and glue the hex bit in?
Brian
sb7979
NW Ohio
I ordered enough material from McMaster Carr to make two of these. Will cost about $15 total for two.
Using Stuart's suggestion of a turnbuckle....that's what it looked like to me as well when I first glanced at it.
It will just have a round shaft, not 1/4" hex.
Going to use one of these turnbuckles, cut one end off, thread and weld a partially threaded rod into it. Done.
Not sure of the scale, maybe it's too small of a turnbuckle, we'll see.
F
fastjohnny
SW Michigan
sb7979
NW Ohio
Before and after pic. Literally took 5 minutes to make. If you only spin in clockwise direction you wouldn't even have to tack weld the stud in.
I used it to roll up some 1 1/2" flat discharge hose. Worked perfect.
joe--h
After looking at McMaster, I ordered 2 turnbuckles off Ebay. I chose that over the above as the turnbuckle had a machined taper rather than machined hex at the ends. I'm planning to not cut the end off, just slice through it with a cut off wheel. On the fence whether I'll loctite in a 1/4-20 threaded rod or weld in a 1/4" hex bit.
http://www.ebay.com/itm/281978019534?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
That same turnbuckle is $2 at Home Depot.
Joe H
bad_idea
Pasquotank, NC
I made one a few years ago for a friend who drives truck. bent a piece of round stock into a u and then welded a piece to the middle of the u. took 10 minutes to make and he loved it.
F
fastjohnny
SW Michigan
Finished project today, need to get a pic. The turnbuckle turned out to be aluminum, so I used epoxy to attache the hex bit. Worked great.
