I was long overdue in adding a parts washer to my arsenal so I went to HF and bought the ubiquitous 20 gallon job. I originally planned on adding mineral spirits and being done with it, but my plans changed real quick once I saw the cost of mineral spirits.
After reading more about alternative parts washer solutions, I decided to stick with an aqueous solution, not only for cost's sake, but for fire safety, health and environmental reasons, as well. The problem with aqueous cleaners is that most are lye based, which is corrosive to aluminum. Luckily, Home Depot also carries one that isn't-Simple Green Pro HD. Apparently its the same formula as the Simple Green aircraft cleaner (aluminum airframe safe) but with color additive.
As I see it, one massive shortcoming with the architecture of the HF washer is that the tank holds a bunch of dirty fluid and sediment and the pump just cycles it. I researched other people's remedies to this issue and ended up with this beast.
First, I fitted the drain with a 1/4" pipe extension, ball valve and nylon hose barb. I used 3/8" vinyl tube for the drain line into the "resevoir."
The resevoir is a 5 gallon bucket placed under the tank. Actually, it's a bucket within a bucket. The white top bucket houses the pump and has numerous small holes drilled in it's bottom. The white bucket is placed in a clear bucket.
The vinyl tubing drain line runs straight through a hole in bottom of the white bucket and empties into the lower clear bucket. This allows liquid to percolate up into the white bucket where the pump is, while trapping the sediment in the lower clear bucket.
The pump then pumps fluid up to the remote oil filter, again via 3/8" vinyl tubing (hose barbs are 1/2" nylon)...
...Part#15728, fits Fram oil filter PH5 equivalents...
...and then through side of the tank to the gooseneck. The gooseneck is screwed into a female 1/4" brass hose barb.
I moved the power switch to one of the legs.
I had to extend the pump electrical cord a bit so it would reach.
I also attached the parts washer to a 1/2" ply base with 2" casters for mobilty.
So far I've cleaned a few things and the set up seems to work well. There are no over-powering chemical fumes, the fluid is staying clean and it does a more than adequate job degreasing. I am using 2 1/2 gallons of cleaner and 2 gallons of water.
Hope this helps someone.
-jloc
-jloc
