Jeeper
Working on a 2002 Toyota Sequoia but this question applies to other cars with similar banjo fuel lines. I want to test the fuel pressure which requires a banjo style adapter which I have on order for my Lang fuel tester.
My question is when you use the banjo adapter with the stock fuel line, do you need to put in new fuel gasket/seals/washers? What about when you reinstall the line with out the tester adapter after you have completed testing. Do you need new seals then?
Is there sort of rule of thumb on when you replace those seals?
