matthewg96
Been looking for something for smaller spaces and lighter work and was looking for suggestions. I found these two systems at homedepot and don't know which one to get. HELP!
I love my Milwaukee stuff but since you say you want them for smaller spaces, Makita is probably what you want. Milwaukee's m12s are big and powerful. My m12 drill is a hair longer than my m18 drill, it's just skinnier. It's also nearly as powerful as the m18. Makita's 12v is tiny in comparison.
I'm a big fan of the Bosch 12 volt system. I have just about every tool they make. Great product and most all of them fit in tight spaces. The mini saws all is fantastic.
If you just need a basic drill, impact driver, screwdriver, ect - id take a hard look at the dewalt 12v max stuff if you don't want to spring for the m12 fuel line, or plan on expanding our into other tools in the m12 line. I have both non fuel m12 stuff and dewalts 12v max. The dewalt is just as powerful and SOOO much more comfortable to hold. The tools lighting is also much better..
If you think u might want a ratchet or hammerdrill, then by all means go Milwaukee, but I actually like the dewalt impact driver , drill and screwdriver much better. It just fits perfectly in the hand. The one handed Chuck on the dewalt hex drive is also a nice plus..
I have to respectfully disagree. I bought the DeWalt first, the 1/4" driver,drill and 3/8" impact. I used it a couple of months then wanting a bigger more powerful drill I bought a 20v max 1/2" drill and it came with a 20v 1/4" impact as well. My oldest son didn't know I had all of this and bought me a Milwaukee Fuel 12v 1/2" hammer drill and 1/4" driver. The Milwaukee 12v Fuel just kicks the DeWalt 12v max in every way. Battery life is much longer and the have more torque. I did an impromptu test between the 12v fuel drill and the 20v max drill. The 12v Fuel drilled between 38 and 41 5/8" holes with a wood bit compared to between 11 and 13 for the 20vmax. (Drilling holes in tree stumps to put tordon in to kill the tree) I took the 20v DeWalt max set back to Lowes after the test. The 12v DeWalt stuff rarely gets used any. I know it comes down to a personal preference. I've since added the fuel 12v greasegun and sawzall and love them sq well,next is the 3/8" ratchet.
I wouldn't buy another 12 V Milwaukee tool.
You are comparing amilwaukee brushless line to dewalts brushed tools.. Youre not "disagreeing" with what I said. The fuel line is not the same as the regular m12 or comparable to the dewalt 12v . I was comparing both brushed since I own both. The regular m12 line and dewalt 12v max are basically identical performance wise. I can sink 3" screws side by side with both impacts drivers and they will tie every time. Also - most of the m12 fuel stuff comes with 4 amp hour batteries. The dewalt comes with 1.5/amp hr with the biggest you can buy being 2/amp hours.. Of course your run tests are worlds apart. They should be, and the prices of what u mentioned will reflect that.
However, if you take the regular m12 drill and impact driver with a 1.3 or 2.0/battery, and run them against the dewalt 12v max with their 1.5 or 2.0/battery, the test will not reveal any worthwhile gap in performance or runtimes.. You have to compare comparable tools.. Run times aside, for me, the ergonomics and grip of the dewalt 12v line is something that makes a big difference. Better lights, better belt clip, one handed bit insert and realease of the 1/4" hex Chuck are some more differences.
You want or need brushless or a larger tool line - yes, I agree it's Milwaukee for that.
Some of the brushed 20v dewalt stuff is nothing spectacular.. The m18 brushed impact driver I have at work will sink lags faster than the brushless 20v dewalt model I have. Dewalt keeps trying to improve their 20v line which is why there's about a half dozen different models of drills and impact drivers.. A brushless m12 hammerdrill with a 4 amp hr battery outlasting a brushed 20v dewalt with a 1.5 amp hr compact battery isnt a great feat either.. Between 2 work trucks outfitted with different Cordless tools and my collection at home, I have alot of lines and models to compare.. The fuel line has A/C motors that are digitally controlled. It's just a matter or programming to outperform a brushed tool - and there is no substitute for having a battery with more than twice as many amp hrs, brushless or not..Good!!! More for us! [emoji481]
Yes, but he was also comparing it to the 20v DeWalt system.
Here's my Bosch compared to my Makita.
did somebody say Bosch
I just bought the m12 drill and its an awesome little drill. I think I'm gonna return it tho and get the impact and drill combo that's not much more money.
No need for my use for the 18v stuff. If I need more power for an impact I'll bust out the IR 1/2 air impact gun or for drilling I'll use the corded drill or drill press
Can someone that has the m12 drill tell me if when you run the drill...is your chuck dead true? When I run mine it has a slight wobble. Is it normal to have a little wiggle or should I return it?
