Puller
born lucky
My Old/New improved drum brake puller.I improved the tip. Lots more footprint and strength. l also gave it some ovals for design.
Bondo
Greenfield, Maine
Ayuh,.... Nice puller,....
In the decades I've been turnin' wrenches, I've found just backin' off the adjusters is all that's needed to pull a brake drum,....
Any brake drum,.....
laydoubtFab
^^Ya, works great until the adjuster is seized or until a shoe lining delaminates and jambs everything up.
Nice puller. Not one of those everyday tools but when you need it i'm sure its a godsend
readhead
Durango, Co.
Ayuh,... Bondo you have lead a charmed life. I have a couple of pullers and they get a fair amount of use. You must not work on many tapered axles.
Bondo
Greenfield, Maine
Ayuh,..... Over the last 5 decades or so, I've worked on 'bout everything that moves, 'n many things that don't,...
But mostly things like 1/2 ton trucks, 'n bigger,....
Donno 'bout a charmed life, but I do have a rather large selection of BFHammers too,....
Ole Slewfoot
Freedom, CA
One of those would make pulling the sticky drums quieter, which is always nice for the neighbors.
When I worked in a safety inspection state, we'd dread testing E-brakes on older cars, it's miserable when they wont release
sberry
Brethren, Michigan
I dont own one but there hav been a time it mat have worked. I just did one with pbrake all jammed up, tool about 30 mind a wheel to work apart
We have reached thru hole to torch adjuster in half too.
