HF O-Ring Assortmant Questions
red73mustang
New Jersey
So Im rebuilding a cheap hydraulic floor jack because I hate to see stuff thrown away and I was in need of some replacement O-rings. Harbor Freight sells several very nice assortment kits that claim to be petroleum resistant, but are the Nitrile ones better suited for this environment than the standard rubber ones?
Regards, Chet
k-os
WI
So Im rebuilding a cheap hydraulic floor jack because I have to see stuff thrown away and I was in need of some replacement O-rings. Harbor Freight sells several very nice assortment kits that claim to be petroleum resistant, but are the Nitrile ones better suited for this environment than the standard rubber ones?
Regards, Chet
I would guess that the "standard rubber ones" are nitrile. Buna-N (Nitrile) is the most common o-ring material.
rlitman
Long Island
They sell a Viton kit as well that is definitely petroleum resistant. I have the Viton orings on the jack for my truck crane.
They work.
http://www.harborfreight.com/180-piece-viton-o-ring-kit-67525.html
+1 You want Viton for petroleum resistance.
But, I will say this. While I had great luck from a $7 buna-n o-ring kit from HF, I returned the $20 viton kit I bought, because most of the rings were misformed, and had flash on the mold lines. Total ****, and useless for sealing purposes.
R
red73mustang
New Jersey
I think the Buna-N type might be the right ones for my application:
Viton is far superior to Buna for high temperature applications. Viton seals provide an indefinite seal for temperatures up to 400°F, and for temperatures up to 600°F they offer an excellent seal for more than 48 hours. Buna on the other hand is only effective up to 250°F. However, Buna seals provide a low temperature sealing option with effective sealing down to temperatures of –22°F, while temperatures below 5°F render Viton seals ineffective as they become quite hard and inflexible.
WVBrady
WV
That's what about half of the ratings said.
bwringer
Indianapolis
Just order the exact o-rings you need from mcmaster. They're cheap.
McMaster even has some decently priced assortments in Buna-N and Viton in standard and metric sizes.
As noted above, Buna-N is the correct material for oil and gasoline; Viton offers added heat resistance over Buna-N in places where that's needed, but it's harder and more expensive.
G_P
Central CT
I'd just go buy individual O rings from a auto parts store or hardware store. I dont think I want to trust lifiting my car to a gasket made as cheap as humanly possible.
rlitman
Long Island
No, and no.
Buna-n has ok, but not great petroleum resistance. Viton is fluorinated to give it more chemical resistance. HNBR is a hydrogenated form of buna-n that has higher heat resistance.
All three sorts of o-rings come in various hardnesses measured in the form of durometer.
rlitman
Long Island
LOL. O-rings are ALL as cheaply made as possible. 99% of the retail price of an o-ring is in packaging. Buy one, spend $1. Buy 50, spend $2. Buy 500, spend $4. The hardware store isn't going to have anything better than an HF kit. OTOH, a parts counter MIGHT, but only if you're buying OEM parts, and that part isn't necessarily going to be "better", just the correct spec.
Fcvapor05
You live in New Jersey- if i were you I'd avoid Viton. It doesn't handle low temps as well, which means your jack might leak over the winter. If I lived in Texas I'd probably use viton and not look back.
