Dremel or die grinder for a very tight access space?
Jacobson
If I wanted to grind something down that was in a tight space (no cutting wheel), what would you use? What attachment would you use on a Dremel for grinding down metal? Is a die grinder a lot stronger than a Dremel?
What rotary tool accessory is correct for grinding down metal?
Astro_Pneumatic_Tools
South El Monte
A 1/8" pencil die grinder is even smaller than a dremel
________________
Chris
Product Manager
image.php
CoogarXR
You can always use a cable-drive attachment for a dremmel too, then you don't have the body of the tool to contend with:
South El Monte
How many seconds would a 6 gallon tank run a pencil grinder for?
427.6 seconds
Heck, I don't know. What CFM? Are you stepping down line pressure? Running it non stop?
What attachment do I need to buy to grind down metal?
1/8" carbide burrs
Your Astro brand is the first search result! I might get this.
http://www.amazon.com/dp/B000RH36WU/?tag=atomicindus08-20
You should
________
Chris
Product Manager
image.php
J
Jacobson
I have this but am not sure what attachment to use.
I used 407, but it sounds like I should use 8193
J
Jacobson
Do those Dremel attachments fit into the pencil grinder?
It looks like the Dremel is 35000 RPM and the pencil grinder is 55000 RPM.
I might try again with the Dremel and use the correct attachment.
Wabash
West Central Indiana
I have a Dremel with the cable drive attachment as well as straight and angle die grinders. The die grinders with carbide burrs are hands down better for grinding metal. With a good assortment of burrs you can grind pretty much in any nook and cranny. The Dremel has it's place for sure, but for me that place usually is on the shelf while I use my die grinders for metal.
metaldad
nw indiana
whadda coincidence.
had to use a dremel, which i usually dont carry on the truck, to enlarge the bore of a fitting. had only (3) grinding wheels, of different sizes, materials. they all got boogered up with whatever pot metal was in that fitting
circo file. burrs. thank you. i need to visit mc master.
dremel has a poor selection, it seems. stopped at menards, and bought whatever they had. (not much)
pendragon1998
NE Georgia
I had to grind off a mangled hose clamp in an engine compartment where I could barely reach my hand down and touch the clamp - couldn't see and had to work by touch. I used a dremel with the flex attachment and a grinding stone like the 8193. Worked pretty well, much better than my initial plan (I immediately thought better of it) of using a cutoff wheel. I decided I was more likely to retain all 5 fingers and more blood if I used a grinding stone. It was a little scary, but ended up working well.
J
Jacobson
What's better for grinding softer metals?
The orange stone 8193 attachment or the carbide burr thing?
I need to grind down some aluminum.
It will be a 1 time use.
Should I get a double cut burr?
Can someone recommend a carbide burr to buy?
I'd rather have one good one than a set of mediocre ones.
http://www.amazon.com/dp/B0097QA7OW/?tag=atomicindus08-20
