Here are some specs for the 1 5/8" unistrut
Thanks! Yes, that seems about right, though I'd add a couple of warnings.
Anyway, my own engineering when I chose unistrut was more off the cuff. I took a 10' piece and laid in on the floor at Home Depot. I put a pair of steel spacer blocks under each end (to get each end up about 1" off the floor) and stood in the middle. It did not touch the floor. I then stepped off of it, and checked with some more spacers to see if it had any permanent sag set in. It did not, so I bought the piece. My largest lifts would be several times my weight, BUT not at a 10' span. In my case, it is connected to the rafters 16" OC.
My heaviest loads:
Two bags of ice melt at a time - 100lbs
Snowblower - 270lbs
80 gallon compressor - 500lbs, though I lifted it in three smaller pieces
Miller welder/generator - 575lbs
Everything else I lift is lighter.
I eschewed mounting brackets. I cut wedges that matched the angle of my rafters. I glued one up where one end of the track was going, and then bolted up one end of the track (holes were drilled in the wedges, to allow lag screws to go through them into the rafters). I then leveled the track, and used brad nails to hold up the wedge at the other end, and bolted that end in place. With the track level, I then put wedges above the track under every rafter it passed, and bolted them all in.
As for the warnings.
1) Those ratings are for a UNIFORM load, not a point load like a trolley! This is a critically important distinction. However, the trolleys themselves have load ratings, and trolleys are available at up to 600lbs, so I would say that 600lbs is a reasonable upper limit to expect
2) It is VERY important to prevent either twisting or spreading of the track. This requires that you have it on fixed supports that prevent twisting, and that your trolley only pulls straight down (pulling at an angle will put the load on only one lip, and can create spreading forces).
3) You need to keep your track very level. If it's off level, the trolley will slide downhill.
