maxpower_hd
OK. I have read several threads on several forums and seem to get differing opinions. I recently test used my Hobart Handler 187 MIG on my Honda/Dayton generator. It is a "professional" model, I don't remember the model number of the top of my head. But it is rated at 5500 watts continuous with 6500 watts surge according to the back of the panel.
I used it this past weekend and it worked fine with only a slight and brief draw on the motor when I strike an ark. I was dialed in at less than full power on the welder since I was only spot welding some fairly thin stuff.
After talking to someone else they told me I was lucky I didn't burn out my welder because the generator isn't an inverter model. Is there any truth to this?
My welder specs say it draws 2.5A at 240V. So that tells me AxV = 4920 watts is what I need to run the welder. With an initial heavy draw and the higher surge rating on my generator shouldn't this unit be enough to run the welder? I am not running it for hours at a time or even doing large welds with it but I would like to feel good about not damaging my welder if I did do some large welds at some point.
What do you guys think?
