Barn door handles
great white tj
Ocala Fl.
I started on two door handles today. Cube twist turned out nice, now to weld up everything to a backing plate.
csp
Franktown, CO
This video does a better job of explaining the cube twist than I could put into words.
ChargerRT
Louisville, KY
Well this is the coolest thing I have seen all day... Made me want to build a forge, any recommendations for a buildplan to follow?
G
great white tj
Ocala Fl.
Sorry guys, I am late getting back.. The anvil is a HB, here are some pic. I use a 3" cutting wheel to score each side and to cut the cubes then I just heat and twist. There is another good video of making a cube twist on you tube. Look up Dirty Smith... very nice work.
fourjeepin
Atlanta, GA
Wow! How many hours do you spend per handle? And could you use a grinder to cut the steel instead of the forge and chisel? Not that I expect to make any, just curious.
G
great white tj
Ocala Fl.
same here!!:beer::beer:
Here are some pic. of the forge build... I have a thread here on """How to build a forge with little $$$"""
