What Tool Purchases Do You Regret The Most?
dhammond
Maryland for now
My regret: My dust collector, purchased new in 2006 when I was working strictly auto, never even made it into the shop to use it, multiple household moves across country, (paid by company thank goodness) now I no longer work auto and find I have more need for diy/carpentry tool storage. Yes, I would sell it, no it's not free. It's currently in the Quad Cities, IA/IL.
90zcar
I regret buying my little red case of snap on bits(hex,security torx, Phillips, etc)
It was almost $200 and I could have built the same set from just as good of ones for probably $40bux
thegroundpounder99
Balm Fl
Does that mean you are looking to get rid of it for a very reasonable price? :thumbup:
They've come down so much in price it's almost cheaper to keep it lol. Think they're $61 and $94ish for the one with accessories now. I also noticed the Hook was down to $250 and that looks pretty useful, idk.
Exceller8
Banning, CA
All these robo grip complaints.....Ive used them plenty of times and think theyre great. Do I own channel locks? Yeah.....they both have their place.
Havent had too many regrets on tools really.....if they sucked they were returned. Not the happiest with my milwaukee angle grinder, and my craftsman drill from my impact driver and drill kit but they do work and fine for the money.
I haven't found anything better for garden hose fittings than Robo Grips. Mine are dedicated for that use. :thumbup:
BikerDad
Utah
I regret buying a Bosch jigsaw. The saw is fine, but I didn't understand that it takes SPECIAL, EXPENSIVE jigsaw blades.
No, they don't. There are two types of jigsaw blades. U-Shank and T-Shank. Some jigsaws will use either. Modern Bosch jigsaws use the T-Shank, which are widely available, and not significantly more expensive than U-shank. A cursory review of Amazon quickly returns T-shank blades from Bosch, DeWalt, Makita, Milwaukee, B&D, Craftsman, Irwin, Lenox, and more.
BikerDad
Utah
Cast iron holdfasts that I bought early on in my woodworking journey. The shaft was undersized, and geometry was bad, so it was almost impossible to get it to hold. One day I was pissed and hit it one so hard while trying to seat it that it broke. A related, subsequent purchase is one that I also regret now, although not at the time. The Veritas Hold Down. It works like a dream as far as holding things down goes, but is almost twice as expensive as the Gramercy Hold Fasts, takes up more storage room, and takes twice as long to use. Does the trick very well, yes, but slow and not a good value. However, at the time I didn't have much choice, given that the only holdfasts on the market were the Veritas and the crappy Asian cast iron jobs. If I were in a situation where I had to work quiet though, the Veritas would be the ticket.
I think I donated or threw away the other cast iron holdfast.
simpler=better
Baltimore, Maryland
I hate those damn two-size slip joint pliers that never hold anything but are somehow the only set in the tractor's toolbox.
Everyone said:
Robogrip anyone?
You kid, but on the farm we used that ugly thing almost every day.
Craftsman strap wrenches. I got the set when it came out, and I haven't yet found out what they're good for.
Use it on your clear plastic drinking water filter housing, jars in the kitched, oil filters....
I've had no interest in rechargeable batteries ever since. I keep hearing the rumor that the batteries are better now--but give me an air drill and a hose any day. If they were giving away cordless/rechargeable tools, I wouldn't walk across the street to get one.
I HATE cheap batteries(any chemistry) and ANY type of NICAD.
You want quality NIMH or LION batteries. Quality means buying the "heavy duty" version of any brand. My DeWalt "XRP" NIMH batteries from 2010 are still going strong and I use them frequently.
Pretty much any modern brand name lithiums are the same. They really are different.
Jure
Croatia
crimping pliers...
Schurkey
At the time I bought the jigsaw, the T-shank blades were at least twice the price of the U-shank, and has less availability.
Things may be different now. I learned to mostly do without the jigsaw.
RonnieC
Orlando, FL
Ha! That's the only thing I ever used mine for as well- when I needed to remove the hose from the hose bib and it was too tight to do by hand.
TangoFoxTrot
Ingersoll rand hammerhead, broke within 2 months of use. (Then like an idiot didn't get it repaired fast enough under warranty) Concept of the tool was good, but no longevity. Now it sits in my garage partially disassembled, but the parts are $$$ and I assume it'll just break again.
Another vote for the Ingersoll Rand Hammerhead. Mine was air powered.
It didn't break, but it just didn't have enough power to be of any real use over a conventional air ratchet.
It was a great concept, an impact wrench that could fit in tighter places, but just didn't have the torque. It failed to break almost every bolt I threw at it so I just stopped using it.
94EG8
Craftsman 3/8 air impact. Sometimes it worked sometimes it didn't and even when it was working right it never had as much power as it should. I sent it back for repairs at least twice when it was new and finally just gave up on it. I replaced it with a used Snap-On IM31 I found on ebay for $67 5 years ago and it's been fine.
SurfHunter
Yeah ! Count me in on the Robo Grip wagon as well. Especially the vise grips..;(
I was able to trade in one of my pliers for the sears equivalent of Knipex.
theoldwizard1
SE MI
WOW ! Someone actually ADMITS to regretting the Snap-On 500% additional mark up !!
Look at it this way. You have a matching case !
theoldwizard1
SE MI
I bought a Craftsman 3/8" air ratchet over 30 years ago. I'll bet I have connected it to my air hose less than a dozen time. What a waste.
It will only spin off nuts if the threads are perfectly clean. At the same time, it will twist your wrist pretty darn good when tightening nuts on clean threads.
I keep thinking about a HF "reactionless" Earthquake 3/8" ratchet, but I think a Astro Nano 3/8" impact "gun" will happen first.
jeepinerdeep
South Central PA
I got a chuckle out of all the Robogrips.....my pops has some he loves. I make fun of him every time he pulls them out of his pocket.
For me it was hammers and prybars. Too light of hammers, too short or flimsy of prybars. I ended up not really liking anything other then SO bars. I've tossed the flimsy bars or gave away anything less than 16 oz in the hammer dept. TC stubby hammers has finally filled a hammer void. Ball peen hammers and even sledges have way too long a handle for me.
Mr_fixit
Rustylvania
Harbor freight style Hydraulic Pipe Kinker. I've used it twice in the last 15 years. What the hell was I thinking?
Sugarfryz
Snap on 1/2 in semi deep impact sockets 15-27mm. My snap on dealer had an excess inventory sale and I couldn't resist buying SOMETHING. I guess they're useful but in 1/2 drive it's kinda unnecessary. I use them only because I bought them and feel like I have to
bobcatdan
Kaukauna,WI
The one that comes to mind because it pisses me offor so much when I try to use it is my 7.2v SO 3/8 mini impact. It can't do anything but piss me off.
Know Wosad
Probably one of the later pieces. A Snap TLL72. It's nothing special other than being long. The Gearwrench stuff is slicker and I reach for them or my 8" Matco first thing. Far less backdrag than the Snap. Oh well. It helps keep the drawer liner from blowing away like 1/2 the other **** I seldom reach for lOL
SantaAna12
Sony Xperia Z3.
An unsupported POS from what I previously considered to be a top notch company.
The lack of support being the main factor.
Oh well.....live and learn.
colt zantop
michigan
When harbor freight came to down, I got the itch to try some stuff. Every bit of it sucked. I do still buy paint brushes there though...lol
bobcatdan
Kaukauna,WI
I fell for that one also and wound up giving it and the 7.2 screw gun to the wife.
The screw gun has its place, not the greatest, but it does what I expect out of it. Had the impact lived up to the 50 ft lbs rating, it would have filled a great nitch for me. Real world it is maybe good for 15 ft lbs.
brownbagg
drill doctor, black and decker bench top bandsaw, and a sear radial arm saw that never been used in the last twelve years
Jim C.
Without giving it too much thought, I'd have to say it would probably be the Sidewinder ratchet. I don't know if it's the most regrettable tool I ever purchased or not, but it's definitely up there. It seemed like a potentially handy tool to have around when I decided to buy it, but to date, I've never used it even one time and probably never will. I don't remember how much I paid for it, but it was a total waste of money. It's big, clunky and stupid. It hangs on a hook out in my shop collecting dust and taking up valuable peg board space. It's only value lies in reminding my not to fall for gimmick tools.
Jim C.
Ctkelly
Iowa
Pittsburgh Pry bars, Pittsburgh plier set. Broke a pry bar, got lucky and wasn't hurt. Pliers slipped and got a nasty cut out of the ordeal.
12 years later....roll the dice and bought a set of the composite Pittsburgh pro ratchets.
Tool_Crazy
I regret buying this Hole Saw Kit.
$189 + Tax
The 2" hole saw broke after 1st use.
I traded it in for some Snap-On tools. Then I picked up a Lawson 61418.
Best decision yet.
Tool_Crazy
Jim C.
I had to google this. Once I saw it, I do remember seeing some of these before.
