Jim Diesel
I haven't used either. How about an introduction?
The pliers of Keiba and Fujija, which is better ? Can you tell me.
I also have no experience with Japanese cutting pliers.
However when comparing with Knipex, it seems that their cutting capacity is much less with regards to max thickness they can cut and the material such as piano.
Cheers
Superautobacs, you are right on what you are saying.What pliers are you looking at??
If you want high leverage/high cutting capacity in a standard sized cutting plier, then the Japanese brands don't offer it. The German brands offer innovative features like the X-cut and TwinForce (Knipex), BiCut (Wiha), FantasticoPlus (NWS) to allow for those specs.
They all share the same downside though. Their maximum opening capacity is significantly reduced.
The Wiha BiCut is pretty cool that it acts like a hybrid. That is, you can use it like a standard plier (with standard opening capacity), but when you need to cut something really hard you can switch to the high-leverage setting with a push of a button.
Personally speaking, when I shopped for cutting pliers, I didn't place that much importance on ultimate cutting capacity. I don't cut piano wire
The box-joint Knipex X-cut opens wide relative to it's small size.
My idea is not the extra leverage but for everyday pliers if I get the piano I don't have to worry that I will damage the edge by points some random pins.
On the other hand is good to also have a flush cut for precise work.
Sent from my HTC Desire 620 using Tapatalk
NT Cutter A-300GR (metal) and Spare Blades.
NT Cutter...my personal favourite....over Olfa and KDS. I got four of them myself.anyone know who sells this rebadged for the US market?
I recently came back from spending my vacation in Japan. I contemplated on whether to take photos of my purchases or to video tape them. I decided to try the latter.
I hope my monotone voice doesn't put you to sleep. Too long of video? Want more details on the products? Pictures would be better?
<iframe width="560" height="315" src="https://www.youtube.com/embed/A-yvf2gSKHA" frameborder="0" allowfullscreen></iframe>
I saw some earlier posts with pictures of Fujiya and Merry snap ring pliers having interchangeable tips. These look like they would be perfect for the occasional user who has grown frustrated with stamped convertible pliers, but can't justify a full set of knipex dedicated pliers. Can someone give more detail on these - quality, usability, availability of replacement tips, cost, and USA supplier?
Finally made some time on one of my Narita trips to take the train into greater Tokyo. All from World Import Tools. Koken and Engineer. Duplicates are gifts for my Dad.
Thank you for the links on those Merry Snap Ring Pliers, Dave. I'm hoping to get a review from Superautobac, maybe need to send a PM. There was another member (gbh) that posted a similar pair from Fujiya, http://www.garagejournal.com/forum/showpost.php?p=5540140&postcount=1446.
That's exactly where I'm at. I'd like a whole set of Knipex, but I would only use them once or twice a year. For as little as I'd use them, I don't mind changing tips. Are the pliers good quality, tight and smooth, and are the tips retained without play? Also wondering if the tips flex, and if they're hardened sufficiently to last.It was because of the infrequent encounter with circlips that I decided it's just not worth spending my money on individual pliers from Knipex or Facom (those were my preferences). I've used convertible types on a few occasions in the past (Channellock and Snap-ons) but I wasn't impressed with them.
Features tools "Made in Japan"
? about those Koken flex extensions. I know Koken makes flex/and fixed extensions. Do they make flex only extensions?
Thanks
