Knipex bolt cutters & piano wire
rick carpenter
Huntsville, East Texas
I'm about to pop for a pair of h/d bolt cutters, Knipex vs NWS/Irwin. I've asked here before and the general consensus was Knipex CoBolts. The Fencing CoBolts open a little wider but aren't rated for hard wire. So my question on which one is...
I do a lot of demo work, when will I run across piano wire in the wild?
I have regular h/d end cutters.
kctyphoon
Jersey/Staten Island
I have the knipex mini bolt cutters and their diagonals. They are both amazing and have held up to everything I but in them. Channellocks not so much.. I would always suggest you go with something that has harder jaws.. ONE item is enough to destroy the jaws on a cutter. I don't see the point in buying something to cut stuff, when it can't cut stuff..
That said., I have lineman pliers and diagonals in over a dozen different brands or models. My knipex stuff is my favorite and hasn't shown any sign of wearing under heavy use. For what I do, diagonals are my most used tool.. Like a Ratchet would be for a mechanic.
To be completely fair, I have the fantastico models of NWS,. They work good but aren't a replacement for standard diagonals. The standard model diagonals with the thin grips from NWS are the only pairs i still want to get. I have them on my wish list with the matching lineman and pump pliers.. Not easy to find, and a bit expensive so I haven't gotten them just yet. I'm sure they will be just as good as my knipex though..
skruft
I would not cut piano or hard wire, wire rope, or any steel wire that I am not sure is soft, unless the cutters were made for it. I have two old, fairly inexpensive pairs.
