Best Screwdriver Bits
Phantom552
Arizona
Long story short, I killed a few screws today thanks to some too-soft and well used bits, and I'd like to avoid that happening again if at all possible, as it wasn't a lot of fun to rectify.
That being said, what are the best quality bits out there? Gonna need phillips, flat, torx, and hex at the very least. Bonus points for companies that also make tamper-proof torx/hex and/or JIS bits.
Arizona, USA Resident, SnapOn/Mac/Matco at work, not that I'm only considering truck brands. No preset budget, if it grips well and lasts under hard use, I'll pony up for it.
Thanks guys (and possibly gals)!
PureLeaf
Im a big fan of VIM. They also do Torx, Hex, not sure on JIS.
Hip2u77
Kansas City
Apex is what they used at the Ford Assembly plant I worked at.
I think I'll give PB Swiss a try also.
Wamsutta
Amarillo, Texas
There's a company called EVCO that makes tamperproof Allen hex bits. I needed one for a telephone junction box one day. I couldn't find that type bit through Apex. Tamperproof Hex is not as common as Tamperproof Torx.
LB-1911
Northwestern Il.
One source for JIS-type bits*
Vessel 1/4" Drive DIN 5260 (JIS-Type) Phillips Bits
http://www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Vessel is making the 1/4" drive bits we carry to DIN Standard #5260. They are NOT true JIS per se. However, we have tested them extensively here and have determined that due to the tight corner radius on these bits (a key ingredient differentiating JIS from Phillips standards), they fit JIS fasteners that you will encounter perfectly.
http://www.rjrcooltools.com/vessel.cfm
Dave455
Sussex, England
Best overall quality - PB Swiss, no doubt about it!
I've used most of 'em over the years, and PB win overall!
Next best - Zephyr. almost as good!
Third choice Apex, Wiha, Wera. They are all 'acceptable'. Some folks rate these as the best, but not in my experience. I've spent many hours doing assembly work with one bit, and I've known applications where a Wera bit will put in maybe a hundred screws, maybe a couple hundred, but wiil always fail eventually. Same job with a PB bit and I havn't broken one!
d.mcfarland
Western PA
If your Snap On driver would warranty them, maybe you should go that route? From what i've heard some will and some won't.
morgantm
Durham, NC
You can buy them directly from Vessel for much cheaper than that website is charging. I ordered 10 packs of the common sizes last year and it wasn't bad at all.
mikebaker1129
Huffman,TX
I am seeing a lot of PB Swiss replies.
Where are you buying the PB Swiss bits? Are you buying individual bits or sets?
jflores
I bought mine from ToolLady but I've also gotten PB from CountOnTools via Amazon or the pbtools.us website.
Kev442
Wi
After ruining 3 P2 screwdrivers this weekend, it's time to switch to bits. Reading up today about PH2's, Bosch ribbed tip (ha ha!) And the Makita gold were deemed super durable too. Anyone have experience with these?
I was going to order some Zeypher today but it was $50 minimum order.
mikebaker1129
Huffman,TX
I know,that is why I ordered 2 of their zbb4 sets.
I could not be happier! 1 set is being used and the other is still in the wrap.
Great bits in my opinion.
Kev442
Wi
Wow. Dropped 4 1/2 pages in less than a day. I guess no one likes ribbed or gold....
skan
Absolutely. They really are unbeatable in all ways. I have all different other bits from Snap-on, Wiha, Wera, and others. None of them come close to the quality of PB Swiss.
How do PB Swiss Tools compare to Makita, Hilti, Zephyr or Bosch Ribbed tips?
Danglerb
SoCal
I wanted some JIS, now DIN 5260, so bought a bitbelt set of 5 from Vessel, about $10 shipped to usa.
I've beaten on a few, but so far haven't broken any of the 100 bit security sets from HF.
