SSolomon
I don't have a pressure washer, so I just filled a bucket with hot water from the shower and funneled it into the tank with a healthy dose of purple power. After rocking the tank back and forth a bunch to stir the solution around and waiting a few minutes, I removed the bottom plug and let it drain out. Some grease clumps came out, but a ton remained. I repeated this process several times (using my whole 2 gallon jug of purple power) and there are still globs of grease left in there - I can feel them with my finger through the bottom drain.
Is there anything that will actually dissolve grease so that it will flush out? It seems like the grease is just floating on top. The water flows out, leaving all the grease behind.
