Requesting bids from GJ'ers
USAFpj
Upstate, SC
Gents, I'm looking to have my 30x50x14 shop completely wired. The way I look at it, if I have to pay $6K+ to get it done, that I might as well see if any GJ'ers were interested in placing a bid. If so, the zip code is 29671 in Upstate SC, and I'm not looking for any discounts, favors, cheapest routes, etc. PM me if interested; here's a few of the items that I'm looking at getting done:
-100 Amp (or larger) sub panel
- Appropriate gauged wire running 120ft from house to shop panel.
-120 plugs every 10ft at 52inches off the ground
-2 240 plugs on one wall. welder, etc.
-1 240 plug on the ceiling for a lift
-1 240 on far wall inside, for welding outside
-a 120 at the top of each corner in the shop for shop fans, or miscellaneous
-120 plugs at the top of the garage doors on the wall for garage door openers, can't do overheads
-a 120 plug high in the middle wall for wall mounted TV
-Shop Lights- 88 4' T8, 14 incandescent for direct work light, and a motion sensored light in the middle of the front of the shop outside.
-Light outside the man door
-a 240 plug on the back outside wall of the shop for compressor and compressor room
-a 120 outside the front of the shop in between the two doors
* Most of these items are debatable, and I'm willing to listen to any experienced input you may have. I can/will dig the trench from house to panel, but will accept a bid for that part as well.
600SL
Connecticut
100 amp and you will be welding. I assume you will also have an air compressor and associated lighting for a 30 x 50 x 14 shop. Might be pushing it unless you intend to keep your welders small.
