shedfullatools
So a while back I had a post about using barn door track as a light duty overhead gantry on the "my tractor forum"and it was a unanimous no. I recently acquired this piece of 1/4" wall steel pipe and thought I could make it work for this purpose. Last night I started, the ends of the pipe will be supported with some very heavy channel and flat stock, these will be bolted to the beam up through the bottom and in from the sides. The pipe will sit on the channel as you can see in the pictures and be welded on from there, The carriage is still in the works but you'll see that later. The gantry will be able to pick things up from the middle of my little shop and bring them over to the workbench, not a problem that it doesn't go to the door because I can back my little trailer right to the workbench in the shed. Anyways the pictures will show everything better then I can explain it sooo...
Think how beefy it would be
The main part is made from two pieces of angle welded together than the plates a come along or hoist will attach to are made from 1/4'' plate. I have lots of little gussets for this I will weld on tomorrow, they will make it look much beefier
Not a hint of movement
More than the shed floor or my little trailer could probably handle
