I'd like to say that every garage door since 1993 should have a torque sensor on the gear atop the operator that reverses the door should the force exceed that needed to lower the door.
On my garage door, I can stop it with one hand.
Also, these safety eyes seem to be a problem for a lot of people, not only are they
a secondary measure after the torque sensor, but the transmitting unit loses power after about 5 years and cost $50 to replace, because it seems you have to buy the transmitter and receiver in a pair. This seems like another government endorsed racket.
So, I made a circuit that you can connect between terminal 2 and 3 on the garage operator and it will simulate the undisturbed beam safety eyes signal. The 555B is a 555 Timer, the main component, which cost $1-$2, the rest of the components, 5 resistors, 2 capacitors, 2 mosfets, and 1 diode, probably cost around $3-$4, so about $5 instead of $50 and the bypasser should last indefinitely.
Be sure to check all laws and neighborhood codes first, of course. This circuit is for educational purposes, solely.
