What is a #2 center drill
Pontiac787
New Hampshire
I have been looking at some 115 piece drill bit sets and noticed that a few come in a case with an open hole in the center. The hole is labeled "For a #2 Center bit". Now after learning that a spotting bit is used to start a hole and a Center bit is actually used when working with a lathe I would think the open spot would be for a spotting bit but spotting bits don't seem to come in numerical sizes. What's going on here?
astroracer
Mid_Michigan
A centering drill is used in the lathe to put a "center hole" in the ends of a long piece of stock that will be turned between centers. it can also be used as a spotting drill for drilling holes, as mentioned.
Mark
larry_g
oregon
I think that your looking at bit sets for lathe use. You need to find sets for a drill press. They should have a place for a spotting bit....;)
lg
no neat sig line
bmxdad
Puyallup, WA
Wow ...
Center drills are very short shanked with a larger dia. body. They're only made to go down .100 or so. They are basically pre-drills. Picture below is a center drill. Tip goes in and the larger body leaves a small chamfer to center the full size drill. Otherwise the split center could walk the drill. They are mostly used on cnc mills. They are used on lathes too, but a turning part will self center. Hole might be bigger, but still on center. A turning tool can walk. If you don't have center drill, a good center punch will work too.
They are not made to drill actual holes ....
larry_g
oregon
Wow ...
I'm going to disagree with you here. As said in posts 6&7 they are for putting a center point in a piece to be turned on a lathe between 'centers'. They are designed to drill to full depth of the 60* angle on the end, not just .100". It so happens that they make a fairly good spotting drill, but that is not their intended use.
lg
no neat sig line
bmxdad
Puyallup, WA
Yes, they are used to put in a center mark for a lathe center, but they do more than that.
Tomatoe ... Tomotoe
