40x64 Shop Build
G-ManBart
G-Man's Big House....40x64 Shop Build
Well, it's been a couple of years in getting here, but I finally have a working barn/shop! It's kind of a long story, so feel free to jump ahead to the pictures...lol. The basics are that it's 40x64', with two 18x12' overhead doors on the front, and one 12x10' overhead door on each end. There is a 12' overhang on the back, and there are service doors near the front two corners, and in the back. My hope was to limit shuffling equipment by having enough doors to hopefully always get to what I need without much hassle.
I partitioned off 24x40' as a shop and the other 40x40' will be the barn/storage area. I should say that I may mess up some of the timeline as it all starts to run together after a couple of years! Don't be too hard on me...I've never built a barn/garage/house before, so I'm learning as I go and making lots of mistakes ;)
So, here's how the basic timeline went:
We bought our current house in July of 2011, and knew we wanted to put up an outbuilding, but spent a lot of time/money doing a remodel, and getting more urgent things done. We were also waiting to buy the two properties to the east of us. The farther one was completely dilapidated, and had been vacant for several years. Vandals had stolen all of the copper, and obviously used it as a crash pad a few times...they even broke through the living room floor to get light down into the crawl space when they were stealing copper wire.
The closer house was still occupied, but the owner had stopped paying the mortgage, and taxes, even though she had a renter in it...nice huh?
The farther property came up for auction first, so we got that one ($20K for 5 acres with the shell of a house on it). One of my neighbors does construction on the side (also drives a big rig), so he did the demo of that house, and then I spent weeks clearing garbage from the property. The owner apparently didn't pay for trash pickup, and simply piled up garbage in the woods, and in holes dug on the property. I filled up a 20yd dumpster, then a 30yd dumpster with all of the garbage!
Eventually, we learned that the bank was ready to foreclose on the closer house, so we called them and told them we wanted to buy it "as is, cash offer". The renter was obviously upset about paying rent, and then getting kicked out, so she kept us in the loop during the whole process. The renter left right after running out of propane, and let us know she was leaving. A month after that, the bank finalized foreclosure, and called us. We did some research and knew that they were owed about $50K based upon an earlier sheriff's auction listing for it. They told use they were planning on fixing it up a little, and putting it on the market for $75K, hoping to get $65K. We made an offer a bit over $50K, and they accepted....a few weeks later we closed. We paid up because we had to have it since we already owned the other property.
This is where it got a bit tricky. This house was still livable (although it was pretty nasty), had city water, and a septic system that was only 9yrs old. I wanted to keep both of those for the barn, for a number of reasons.
One problem we ran into was that a local ordnance prevents you from having an outbuilding on a lot without a primary structure. In other words, if I knocked the house down, I couldn't put the barn up. The other problem was that you can't combine properties with more than one primary structure. So, I had to knock the house down, legally combine the two properties, then get the building permit for the barn. Needless to say, this wasn't a fast process.
Now back to the septic, and water. I had to get the county to give me a waiver to keep the septic, because normally, they require an open hole inspection after demolition showing that you removed the tank. They came out, inspected the field, and determined it was in excellent shape, so they granted the waiver. I also had to get a different township to work with me, because they provide the city water. Normally, for demolition, they charge you $850 to sever the line, and if you want to hook up again, they charge you a boatload of money for a new tap (thousands) I got them to agree to sever, then reconnect for "only" $850 for each event. That's expensive, but a fraction of paying for a new water tap. My argument was that the tap was already in place, and they wouldn't have to run new lines, etc. I also managed to get the bank to pay an overdue bill from when they owned the property, so that greased the skids a little bit.
At this point, I had a demo permit in hand, and the same neighbor did the demolition on the second house. It was a manufactured home/trailer type, with a huge crawl space underneath spanned by some really nice 24' long 8" steel beams (beams came in handy later). The crawl space turned out to be a bit of a problem in the long run. Because of how the lot was graded, and the deep crawl space, it meant we couldn't put poles in easily and couldn't do a trench footing (can't backfill, then dig a trench, as it will collapse). Two different builders looked at it, and said the same thing...it was going to have to be a formed foundation. I actually like that a lot better than putting poles in the ground, but it certainly increases the cost when you start adding all the extra concrete!
In order to keep the city water and septic without a lot of hassle, we put the one corner of the barn right where the corner of the house had been so the hookups are in the right place, and we set the elevation based upon the septic tank.
We (me, same neighbor that did the demo, and another who's done a bunch of work with him) dug through some really nasty fill that was put down before the old house had been built, got to virgin sand, added more clean sand, compacted, and then the neighbor that did the demo brought in his basement concrete forms, and we went to work. He does a lot of basements, so we turned his 4x8' forms sideways, and poured a 12" thick 48" tall foundation. We got the backfill done, then set to work on preparations for the concrete slab on one side of the building.
The plan was to have a concrete slab for the whole building, but we were racing the weather, so I decided to only pour the part of the slab that I plan to heat (radiant). That part I'm calling the shop, and is the 24x40' side. We put down plumbing for a complete bathroom, with toilet, sink, and an extra large shower. I wanted the shower for when I'm really dirty, and don't want to track it into the house, but also so we can give our large dogs baths easily. For that reason, we also put a nice center drain in the floor...big dogs, water, you get the picture! We put down 2" R10 foam board insulation, got the Pex tubes in place, did a pressure test on the system, and ordered some 4,000psi concrete with fiber mesh, and added heavy gauge wire sheets as we poured the concrete. We did a bit more backfill, and then handed it off to my builder who did the walls, trusses, roof, and exterior metal. I decided to go with 4x6 posts (6x6 on the corners) set in Sturdi Wall brackets from Perma-column. they're not cheap, but I know they saved the builder time, and that was one of my concerns.
When the builder was done my neighbor and I did the 40x40 slab. After that I ran most of the electric service while things were open. I got lucky because my neighbor had a truckload of 4' wide 32' long rolls of insulation he got from a demo job, and he gave me a huge pile of them....they fit between the trusses perfectly. I hung those over the shop area before building the partition wall. I supported them with twine and hung a vapor barrier. At that point I built the partition wall and then hung the liner panel ceiling over the shop. Next I moved on to insulating the walls of the shop, adding purlins and 1.5" foam board between the purlins. Then the wall steel went up and I started framing out the bathroom/utility closet which also has a deck built on top out of 2x10s to be a storage platform.
That's pretty much where I am right now. I still need to install the mini-split/heat pump (in the one area I have hung the wall metal) and start building the radiant heat system. After that I'll work on plumbing the rest of the bathroom....have I mentioned I hate plumbing...that's why it's last! I also plan to build my own workbench(es) and the primary one will be attached to the long wall of the bathroom/utility closet.
As a side note we also bought the 5 acre vacant lot that was farther to the east than the first one we bought, so now we have 20 acres with about 1000' of road frontage.
I'm getting ready to pour a concrete slab under the 12' lean to on the back of the barn. I plan to build a welding/grinding table out there so I can do dirty work outside when weather permits.
I'll put a link to the Photobucket gallery, and some of the major milestone pictures in the next post. I have no idea what I'm going to do with all the free time I have when I get done with this project!
G
G-ManBart
Here's the gallery:
http://s454.photobucket.com/user/G-ManBart/library/Barn?sort=3&page=1
Here's the nasty house we knocked down with some of the metal scrap from the previous demo piled up:
Demo day:
Foundation going in:
Plumbing prep:
Shop Slab going in:
Beams for the big overhead doors up:
Lots of people ask me what the Perma-Colums look like:
Start of framing:
Getting read to start hanging metal:
Waiting on the doors:
I know it's a bad picture....just after the last door was installed:
Insulation hung over the shop:
Slab for the barn:
Scotty, we have power!
Partition wall up and insulated:
OSB over the insulation:
Hanging the ceiling:
Ceiling done, and the lights in place:
Bathroom/Utility closet framed:
Partition overhead door installed:
Video walk around showing where's it's at (few things done since then).
LXCam
Looking great. Man that foundation and fill was one hell of a lot of work, how long has this taken again?.
G
G-ManBart
Yeah, the foundation and fill was a pain, but it's in the past :beer:
I made a mistake in my first post. We started the demo of the second house in Sep of 2103 and started on the build immediately. It was dried in right at the end of Dec 2013 and I've been plugging away ever since.
I'm putting a 50yd pistol shooting bay behind it now:
G
G-ManBart
The reason I went with 18' wide doors on the front....plenty of room for bigger equipment.
G
G-ManBart
I took this today from the same spot as the first Demo Day picture....hard to believe it's the same place!
Here's a pic showing why I went with 12' wide doors on the gable ends...plenty of room for my single axle dump:
Here's a pic of the bathroom/utility closet with the metal finished. I'm going to build a bench that will go where the plywood is under the pegboard, but haven't completely decided on the details.
The little bench in the picture isn't used as a work bench...it's for when I chronograph and shoot accuracy groups with my pistols. Eventually I'll build something nice to go under the lean to, but this is good enough for temporary use. The vise isn't attached...just set there temporarily. For the vise geeks, it's a Parker 824.
BUGTHUG
Kansas
Love the shop. I have a question about your picture of the perma-colums. That is what we call a pressure treated post, its shot with a chemical so it can be direct buried. The old days they used arsenic, but EPA changed that.
What I always thought the perma-colums were, are usually 3 2 X 6, or 2 X 8 or similar. They make like a sandwich were the pressure treated are on the outside and the bottom of the one in the middle. Then the regular wood is up above the ground, and the outside ones are regular wood. Usually they are about 5' of pressure treated on the bottom of the colume, then the rest of the post is regular wood. Morton Buildings use this design on their buildings. You can look at their site and maybe it will make it clearer of what I'm trying to say.
G
G-ManBart
Thanks!
I should have been more specific. The brackets I used are Sturdi-Wall brackets made by Perma-Column the company. They also make Perma-Columns like you're describing along with a couple of other models. The brackets I use also come in other configurations, but I didn't need anything more complicated than 4x6 and 6x6 posts for my build.
In case anybody wants to check out the other kinds of brackets and columns, here's their website:
https://www.permacolumn.com/home
drivesitfar
GMan: just saw your thread and i'd love to have the space and equipment you do. i'm hoping to get there SOME DAY and hoping SOME DAY isn't another way of saying NEVER.
WELL DONE SIR!!!
also how many of those machines do you own and which ones did you just rent or borrow for a few days?
any updated pictures of a bench with a vise bolted to it or a few sitting on it?
cheers (ice tea for me)
BUGTHUG
Kansas
Thanks, I have the same brackets on the post that were on the concrete. I had a 30 X 40 pad there from the first building that I had them removed it.
I see your barn is pretty much full all ready, bet you wished it was bigger. Just like everyone that builds.
Nice layout, I like the way you have the door arranged. Should be able to get to things without having to jockey things around to get in or out.:thumbup::thumbup::thumbup:
G
G-ManBart
WELL DONE SIR!!!
Thanks Drives! Don't give up the dream...took me years to get this thing planned and built. Honestly, it's partly practice for when we plan to build our retirement home....I'll do a lot of it, and be able to ride heard on contractors because I'll know when they're blowing smoke.
All of the machines besides the tracked Bobcat (neighbor's machine) and the tele handler (contractor who did the walls and exterior metal) are mine. I did sell the blue compact tractor to buy the Case backhoe, but other than that I still have everything. I sort of have a little excavation company started, but I don't go anywhere with it :D
I don't have any of my benches built yet (have a big one in my basement, but none in the shop) so this is the best I can do for now...you'll recognize a couple!
drivesitfar
GMAN: I bet when you decide what kind of benches you need or want that they will be AWESOME. keep an eye out for old Bowling alley or shuffleboard wood and of course for some old steel plate for a few wood and steel benches.
also take a gander at this thread for vise and grinder stands if you might want to see a few good ideas that other members use for multiple vises.
http://www.garagejournal.com/forum/showthread.php?t=252799&highlight=vise+stands
of course I recognize a few of those and wish I could have had my hands on them. they do look like they are part of a big happy (and growing) family so maybe some day i'll stop by to see them in person.
cheers
SiGmA_X
Portland, OR
I started reading the description of the shop and saw the door size and thought "you know what they say about big doors...big toys!" and you surely didn't disappoint. You have some good equipment there sir! Also quite a nice build. I like the metal finish in the shop.
Looking forward to seeing the finish work and hopefully projects that you produce!
G
G-ManBart
cheers
If you do stop by I'll make sure to have plenty of iced tea handy :)
I've been all over that grinder/vise stand thread and think I have the makings of a monster worthy of that thread!
Part one is 210lbs of sprockets that will be the base after I weld them together. The upright is a 10" I-beam that fits right across the opening in the center:
G
G-ManBart
Finally getting to the concrete out back....truck is scheduled to bring the concrete at 6:30am tomorrow!
G
G-ManBart
They did Drives! Luckily we had just enough concrete left over to set 3" galvanized pipes at the end of the driveway to hang a 16' gate I've been looking at for a year :)
G
G-ManBart
no metal in that pour?
No, but we added fiber. I'm not planning on parking anything on it and certainly not driving anything on it. It was 4,000PSI 6" thick, and that should be fine for what is nothing more than a patio. The base was compacted and then sat for about 2 years, we added grave and compacted again, and it's not gong to get any water under it, so I'm really not worried.
G
G-ManBart
I'm ready to pull up a chair and have an ice T:)
Me too! I bought a mini-fridge for the shop last weekend so at least now I can keep cold beverages handy :thumb up:
I think we're going to move our BBQ there as well...keep it under cover. I guess that means I'll have to make a nice table to go next to it....and probably some chairs....and whatever else my wife thinks of :)
G
G-ManBart
I haven't posted many/any pictures showing the view from behind the barn....here it is after the new concrete under the lean to. The area I'm standing on is a low area I've been bringing fill dirt in...that's why it's just dirt.
drivesitfar
GMAN: cement work looks great. i hear you on the outdoor picnic or entertaining area, but i'd use it for storing materials or machines. probably since i don't have an acre or more or a huge shop.
since you like vises and probably need to cook a few how about an old fridge oven and metal cabinet sink combo along the wall. i just saw this combo on my CL for $100 and even though i don't like that style fridge as well as the rounded ones i did like the oven and sink so saved a picture for you.
cheers and hope you are having a great weekend.
drivesitfar
GMan: this is more like the oven i'm hoping to have in my shop some day with one of those old rounded fridges next to it full of ICE TEA.
these aren't my favorites, but close as i could find on a quick Google to show you.
cheers
BUGTHUG
Kansas
That reminds me of an apartment I rented while going to "A" school in Great Lakes Ill. It was a couple of blocks from the South gate. You talk about a war zone, people use to drive by and shoot into the Mc Donalds. We had street walkers and drunks sleeping on the sidewalks. Man the good ole days:D
The kitchen had a setup just like that , except it was rusted, the doors didn't shut and the water dripped all the time. Except in November when it was so cold it had some ice on the faucet. That was back in 1976. "GO NAVY"
G
G-ManBart
cheers
That's a good idea! I'm already planning a washer/dryer for my work clothes, and already have a fridge and microwave. I've been thinking about a powder coat setup, so an oven is a must :)
G
G-ManBart
I've been having random people driving around my property lately, and had just enough concrete left to set posts for a 16' gate I had waiting.....got it hung today.
drivesitfar
GMAN: from my chair that gate looks pretty damn level. nice job and hopefully the snoopy drive bys are just admiring your new garage and not looking to rob you. did you set up some cameras and security just in case?
i like the way you think with the outdoor fun area in the carport you just poured the floor for. have you seen some of the BLO vises that were baked on in a smoker? they have a glow about them, but i guess that they stink pretty good while baking so outside is a great idea.
cheers and hope you had a great weekend.
G
G-ManBart
Thanks...the gate is close to level. I think it's a little bit high on the hinge side, but I can adjust it if needed. I'm considering putting an electric opener on it, but it'll have to be a solar charged model since I don't want to run power 300+ feet to get to it.
I have seen a vise baked in a smoker...pretty cool!
We had a weekend without A/C for much of it (90+ each day), and the repair guy just left, so I'm a lot happier now :thumbup:
G
G-ManBart
After seeing all of the folks with nicknames for their shop builds, I decided mine needed something similar. So, from now on, I'm calling it the "Big House" since it's kept me prisoner for the last few years! :)
G
G-ManBart
Very nice build, what did that build run you ($$$)?
Oh Lord, I'm afraid to count the receipts at this point! One big expense was having to hire a local guy to erect the walls/trusses and do all the exterior metal because I was traveling for work for a couple of months, and wanted to beat winter.
I have a tally going for all the big ticket items and I'm in the ballpark of $65K. A good chunk of that was hiring the guy to do the walls/exterior metal, but I also had 82 yards of concrete that was $13K before hiring out having the trench dug, forms put in, etc. Having five large overhead doors added something like $8K, so just those two things alone are 1/3rd the total cost.
I haven't decided if I'm ever going to add up the pile of Home Depot, Menard's and Lowe's receipts I have!
To be fair, this is a lot more like building a house than a barn. With a poured foundation, full slab, radiant heat, plumbing for a full bathroom, 200A electric service, steel interior walls, lots of lighting, etc, it adds up quickly.
The only planned big ticket items I have left are the radiant heat boiler system and the A/C mini-split. At some point down the road I'll bring in 3-phase electric power, but I'm not in a rush for that (it's at the pole 50ft from the barn, I just need to pay to have them drop a transformer and pull the wires to my meter).
Luckily my wonderful wife asked about the cost when we started and said "what's this going to cost, $100K?" and I said "no, it'll be less than that"....pretty sure I'll be able to keep it under budget :thumbup:
