kunkernator
Finally got my whole welder setup all done!
Inventory;
Klutch 220si Mig/TIG/Stick welder w/spoolgun
80CF 75/25 argon mix
40CF argon
Lotos LTP5000D plasma cutter
Klutch welding cart
Still waiting on a matching set of flowmeters for the bottles, along with a 3 way ball valve. That way it will be completely tool-less to switch gases for aluminum welding.
Just got the welder and the second bottle in today (both private owned tanks). I have to say this welder is top notch. I havent seen many reviews on the Klutch welders, so i may do an in-depth one.
And as required.... Pictures!!! I want to note in the last picture, i mounted the air fitting for the plasma cutter on a stiff part of the cart. It allows a much more "solid" surface to push and pull off of when connecting and disconnecting air, as opposed to the flimsy regulator mount.
Inventory;
40CF argon
Klutch welding cart
