Can you use a band type tpms sensor?
Were the valve stems put on the inside for aesthetics or because they had to be, due to the offset?
What about something like those Flush Mount Valve Stems?
Summit Racing among others sell them.
http://www.summitracing.com/oh/parts/gor-vs407c/all
I was going to suggest the same product. Flush valve, but must use an adapter to charge the tire with air. May be your only option.
I assumed that the inside valve stem was for appearance. Now that I look at the offset, it would have been interesting to place them outside.
CT
I was able to track down a used & a new OEM BCM. hoping that will do the trick to get it to start. I am able to program it up to point of needing the Key re-programming.
Have a couple volunteer's to tow it to the dealer to have that done.
the more chrome.... the better!
All your NOS parts, you've got to have a chrome one sitting on the shelf..![]()
I agree with Robert, chrome dash cluster is my favorite.
I have to wonder how argent would look?
As much as I like the idea of keeping ECO2 looking totally stock, I do like blending the 2015 gauges into the 66 dash (assuming that wiring hasn't already been removed)
Hey TW-I'm a little reluctant to weigh in here since every time you've done something different from what I would have it comes out great but since you asked. I like the '66 cluster for EcoII. I'd try to subtly integrate a check engine light and the cruise control controls somehow but keep it as stock looking as possible. On EcoI I'd use the new custom center gauge that you bought and put something in the outer two locations. I've always thought that they look like somethings missing without gauges there. I'd need to know what the rest of the interior looks like before giving an opinion on color.
I may have left out the portion of while at dealer the tech programmed the PCM, BCM, parameter reset and keys to what I thought would work & truck did run.![]()
Earlier you commented on the weight of Eco2
"For some reason I find weights interesting. Total weight, front to back bias . .
This is complete rolling chassis for Eco 2. 2389 lbs. Hoping for curb weight to be 4000 lbs or less."
Well the 2015 F150 with 3.5L Eco runs 0-60 in 5.8 seconds and does the 1/4 mile in 14.6 secs at 95mph and it weighs 5220. At over 1000 pounds lighter, Eco2 is going to be a rocket ship!
Awesome!!!!!!!!!
Very nice, you'll be flipping a coin to see which one to drive in no time.
Sent from my SM-G928V using Tapatalk
yep, I have mentioned before that getting old the mind has a tendency to slip once in a while . .That little piece of update slipped your mind???
"Pretty Good" Yeah, Important news too. Mind is going, sometimes too many details other times miss the details . .Hey, you sneaky little so and so! That's a fairly important little detail!
That's awesome news!!!
Yes, Have 2 Extra's. The wheel builder is getting new Forgings on June 6th. In design stages now but spare will be only 7" wide so no clearance issues expectedDid you get a flush mount for your spare?
And add a few HP . .Earlier you commented on the weight of Eco2
TW -
Yikes! I didn't realize they were this quick!!! Are the EcoBoost trucks going to whip the 427 truck in the quarter???
Congrats on getting it running -- I know that had to be a great feeling when it started for the first time in the 66 chassis.
Scott
Sweet!
Your work is top notch!
