BellyUpFish
Splicing #6 copper to #2 aluminum URD.
Aside from skipping the splice and running aluminum the entire way (which I'm considering) what is the best method to splice these two together?
I'm running a feed to my detached garage and while the house was being built, the electrician ran a short run of #6 copper out for me to splice into for my shop run. I'd love to rip it out and install the #2 aluminum, but that stuff is so stiff, it may prove problematic to fish into the panel in the house. Basically 2 90* turns in a very short space, unless I drill a hole through the brick and go straight up into the panel..
So, while I contemplate that decision, if I splice, I need to figure out the best way to do that..
I know split bolts have been used since the ark was built, but being aluminum, I'm a little concerned with the expansion/contraction issue and having to tear into them yearly to check the secureness of the connection.
What is better than a split bolt for this operation?
