Air compressor under 1000$
by921
I have given up on using my 20 gallon compressor. I am painting my jeep and that involves using a da sander. Other tools that I am using is impact, die grinder, and cut off tool. I was looking at the 60 gallons at lowes and home depot and like the price of 500$ but that would probably not be enough air compressor. But I saw a air compressor at northern tool that may work but do not know if it is the best I can do for under 1000$.
Has anyone used or have one of these. I like that it was 18 cfm at 90psi, but not that it was made of mostly foreign parts. I will not be using this every day but I still want something reliable.
CompressorPros.com
SC
I've seen those and wondered how they get 18 CFM out of that small pump. I'm sure they sell a bunch of them. I know PUMA makes at least one of their portable units, but not sure on this one. It's hard to find any single stage unit with a non-Chinese pump. Jenny does them and they make great stuff, but you pay for it.
We have a couple small two stage units for around $1000, but they are 15 CFM machines.
Hope whatever you get works out for you.
Davefr
OR
IR's low end compressors are garbage. You'd get a much better unit buying the 60 gallon HF unit. (made by Bel Aire)
CompressorPros.com
SC
Only East Coast units are now being made by Atlas Copco, who makes Belaire, for Harbor Freight. Another manufacturer is building the units out West. Very different machines. I'm sure it was a money decision.
by921
I would rather not buy a harbor freight. I do live on the east coast though. I was looking on notherntool because if you spend 1000$ you get a 200$ gift card. And they don't have to be a 60 gallon an 80 would work as well.
Fixin'Stuff
HotterNHellHouston
I found this interesting on that page:
"American Pride
•Proudly built in the U.S.A."
Perhaps they meant to say proudly "assembled" in the U.S.A.? ;)
It's a damn shame really. So many once-iconic brands are selling junk these days. I suppose it's the only way they can even begin to compete with the tidal wave of cheap Made-In-China ****. :(
CNGsaves
KS and OK
OP . . . to get compressor you want, really need to look used on CL.
For $1,000 you can get a very capable quality compressor . . . IF . . you look.
May have to drive a distance to get it, but in the end a Quincy, Curtis, Saylor-Beall, Kellogg-American, etc will be what you NEED with air demands of DA sander, etc.
Look for 2 stage 80 gallon.
by921
I was working at my bosses house today and he has the 60 gallon kobalt, and just to see I took my dewalt da sander. I was able to sand for 5 minutes straight at 90 psi with out have any issues. I guess if was sanding a long time it would slow down. I expected it to slow down within a minute or so
md21722
Mt Juliet, TN
I know a guy with a Kobalt and he's happy with it especially since he got it on large discount $269. Just be advised these cheap compressors at considered disposable. If you can get the original HF dual stage that is highly rated for its price. Out here in Colorado they've changed them to a single stage. Champion and Saylor Beall make the best air compressors IMHO. Jenny (Emglo) is also excellent but rarer and Quincy QT are often available even in stock at Northern Took. I like the Champion and Saylor Beall because they run at 710-734 and 845 RPM respectively. The Champion has no head gasket to blow. They've been making them the same way since the 1930's-1940's. Good compressors cost around $2500-2700. Get a TEFC motor if the compressor is in the same place as grinding or sanding. ODP motors **** air through the windings to cool the motor. TEFC blow air outside keeping the windings clean- they are better for dusty, dirty conditions.
by921
I will probably end up with the cheap kobalt. I want to get ahead and buy a nice one but after using his I think it will do. Plus I am only 19 and working in somebody else's garage. It it were my own garage I would go ahead and buy a two stage Quincy or ir but I guess I can wait on that
Bluejoe
I say get what you need now and be done with it. Why pay twice. I'm looking at Craig's list to find a saylor Beall or champion. Check out TP tools. I've been around that corner several times buying something cheaper or not capable and regretted it just to put out additional monies afterwards.
CompressorPros.com
SC
I know it's not under $1000, but we have been offered a couple Cast Iron 7.5HP Chicago Pneumatic air compressors at a low price to try and move them.
$1599 with free standard freight and a Two Year Warranty that covers everything on the machine.
RCP-C7581VS
Citation
Indy
Given your original post I would recommend the used compressor option. But if you aren't in a long term house /garage setup I think we need to ask about available power. Also, what type of compressor do you currently have? You said 20 gallon but how many cfm?
The 60 gallon is nice since they aren't too heavy to move with one or two people later. Another nice thing is you can run that off a 20amp 240 volt circuit.
Given you think the Kobalt is up to the job you might consider these ideas. First, if the pressure ranges overlap, run you 20 gal and the Kobalt in parallel when you need extra air flow. Assuming they have similar pressure ranges that would give perhaps 15 cfm @90 psi and 80 gallons of air. There are some details here that have to be considered like the 240v compressor should kick in first (ie at a slightly higher pressure) and you need to have separate circuits to power these compressors.
Another option is to get a second 110v compressor and run it in parallel. If you find one cheep this is the low cost option. With a second 20 or 30hp compressor you will match the flow of the Kobalt and have 40-50 gallons of air. This is the cheapest option. It also is the easiest to move which, at 19, would be a concern for me. It does require having a second 110v circuit in the garage.
Anyway, as a permanent installation using two compressors isn't my first choice but since you are likely to move in just a few years and you don't need all the air all the time, this is a very viable option.
CompressorPros.com
SC
If I may pose a question. Is it possible to get a Jenny k2a-30 with a vertical tank from you guys? I only see that you have a k15a-30. I'd like the extra HP. It will be a while before I can acquire one as I see they are a bit pricy. But I'd like to know if one can be had.
Jenny has so many compressors, I haven't listed all available. I just loaded the K2A-30V. Typical lead time would be 5-7 days to ship.
CompressorPros.com
SC
Thats not bad at all. Is there any way to get a price for that unit? I'd really appreciate that. There aren't a lot of places that carry Jenny.
It may be overkill for my garage, but I'd love to have a quality unit that is serviceable by me and know where to get parts. I don't mind paying for quality at all. After looking for days at reviews on compressors, this seems like a viable option depending on price. I can't go too crazy. Wife will kill me.
Thank you for the help! What is your opinion on these units based on your experience? And do you have any recommendation for a 115V alternative you feel is comparable? Just in case price is too high.
If you will, e-mail me your city, state and zip ([email protected]) and I will give you a quote. It all depends on my freight costs.
There is no doubt that Jenny is top quality. We don't sell a lot, simply because they tend to cost a good bit more. They are one of the only companies still building pumps in the US.
Citation
Indy
What's the typical application for a unit like this? I assume it's a 20amp motor. I ask just because it seems like a specialty setup. It would need more current than a typical 110 outlet thus may require a dedicated circuit. The 30 gallon tank is small by stationary standards. 3hp, 60gal units from most box stores are often much less expensive. BTW, I do get that some industries have specialty needs. At work our lab refrigerators look like white box refrigerators but they cost far more since they are certified, etc.
CompressorPros.com
SC
This is more of a space saving design. 2HP 115 volt units are typically made to run on household circuits (20 amp). Most smaller tank units like this we sell are portable, like the BelAire 5026VP. We also sell a BelAire 60 gallon unit, 2061V for those who want a little more storage, but are limited to 115 volt. Jenny compressors are a premium brand because they are great machines and built in the USA.
SgtHawkUSMC
US
I've had the BelAire 216v for more than 10 yrs. It's more than enough for most hobbyist garage guy's needs. I love mine. The only thing I don't like about it is the 3,750 rpm motor. I'd rather it was the slower one, but it was also around $800 delivered to my door. What more can you ask for?
Make sure you know the difference between acfm and scfm when you're looking.
https://www.aircompressorsdirect.com/BelAire-216V-Air-Compressor/p4839.html
Bel Aire 216v by Dave H, on Flickr
IMG_20160326_132522 by Dave H, on Flickr
IMG_20160326_132528 by Dave H, on Flickr
lmalcomb
Southeastern Indiana
driftpin
Always a good idea to include your general location (under your screen name), someone might know of a local deal. I have a friend from-whom I've been buying stuff for years, I got a Saylor-Beall 80 gallon 240 V Baldor 1 ph. off him, rebuilt, for < your (O.P.) price range. He sells, rebuilds and services air compressors over 3 counties, from one location.
driftpin
Industrial Air IV5076055 60 gallon Air Compressor Review:
best 20 gallon air compressor
bestaircompressorguru.com/best-60-gallon-air-compressor
Equipped with the great features Industrial Air IV5076055 60 gallons is one of the best 60-gallon air compressors under 1000 out there. This compressor has high powered output, and cast iron durability leaves nothing to be desired regarding performance or durability.
Working PSI:
This 60 gallons two-stage air compressor offers an industrial performance of a maximum PSI of 175 that gives enough power to use multiple air tools
Does not overheat:
The electric motor features thermal overload protection to protect overheating, and the air receiver is an industrial-sized capacity.
Easy to transport:
The wire form belt guard improves compressor cooling for efficiency and transporting becomes easy with the 4 tie-down holes in the platform base.
Durable:
The industrial Air IV5076055 is pretty durable and built with stainless steel reed valves and ball bearing. Instead of a standard single cylinder pump, this air compressor comes with a two-stage unit.
Curious, I went to the website and apart from it probably being an attempt to sell the guy's company products, it seemed to be well-organized. Some mis-spellings, but overall, I didn't spend a lot of time picking it apart. I didn't compare the name-brand info to the companies' own webpages.
https://bestaircompressorguru.com/best-60-gallon-air-compressor/
The one at the top of their list, after a Quincy:
https://www.amazon.com/dp/B01IR1GQ3I/?tag=atomicindus08-20
That's the one in the O.P.'s post.
vanapplebomb
Holland, MI
For a good brand new unit, I recommend spending about $300 more to get this one:
http://www.homedepot.com/p/DEWALT-80-Gal-Stationary-Electric-Air-Compressor-DXCMV5048055/204068487
They're Kellogg American knock-off pump w/ disc valves but w/o the centrifugal unloader. They replaced the centrifugal unloader w/ the modern unloader that's built into the pressure switch.
These units no longer use that style of pump. The first photo is dated, showing the old pump. Sanborn (Who makes the 30-120 gallon Dewalt compressors) has a new more efficient Pump with full floating reeds instead of the disk valves. It’s a pretty nice pump actually.
That Dewalt has about a 200 buck markup on it because Sanborn and Dewalt both have to make money on it. For roughly the same price, Sanborn markets that pump with a Baldor motor and magnetic starter under their Industrial Air Machine brand. The tank does not have the built in regulator and quick disconnect assembly that the consumer oriented ones have like the Dewalt, but you get a nice pump and a good industrial grade motor on it. If your working the compressor hard, that Baldor motor is a good choice. The Century motors on the Dewalt listed are fine for consumer use, but at the end of the day they are a cheap electric motor, and your mileage may very.
