Remember the Morton Salt slogan?
HoosierBuddy
Southern Indiana
"When it rains it pours".
So, last Friday I was looking forward to a little quality time in the garage wrenching with my 20 year-old son, who called earlier in the week to report his Fox mustang's heater core was leaking. While we wouldn't have time to pull the dash and replace it, we planned on at least pulling the hoses off and bypassing it so it wouldn't leak onto the carpet. The plan was to buy some time until we had time to fix it correctly.
Well right on time, he rolls into the driveway and gets out and lets me know that the a/c stopped working completely on the drive down. Of course I checked the fuse. Not it. Took the glovebox out and got my multimeter hooked up. 12V to the fan with the switch on, but the fan isn't turning.
So we pulled the entire blower assembly and hooked the motor up to a second battery (kind of like asking your doctor for a second opinion.) No joy. I checked all around and none of the autoparts stores in my area had a blower for a 1989 mustang in stock, so I ordered one. Meanwhile it's supposed to hit 95 in the coming week and the boy has a job interview on Friday after lunch. So I told him we'd leave the mustang apart until the parts came and he could take his brother's car back when he left on Saturday.
Saturday rolls around and I get up and take his brother's Subaru WRX to the gas station to fill it up. On the way back, one of the belts is screaming so loud I can actually smell burning rubber. ****. And, as we're supposed to leave for a wedding in an hour, I'm already wearing a suit. Suit and all, I check it out and first thing I notice is there's coolant under the car. I'm thinking water pump failure and coolant all over the timing belt and that's the squeel. That's about an 8 hour job and we're late leaving for the wedding.
So, we park the subaru and go to the wedding. Luckily, his grandparents live in the town the wedding is in and they have a spare car they offer to loan him for the week so he can get back home and have a car to drive to work for the week and his job interview. The car (older Toyota Prius) even has a/c...so at least he's in good shape there.
Sunday we get up and I start in on the Subaru while the wife starts mowing. 5 minutes in (I didn't even have my tools all drug out) the mower stops and she comes into the garage. "The belt came off the mower". Wonderful.
So, I check that out. Yes the belt came off. It came off because the tensioner pulley has flown apart in 3 different pieces. ****. Sunday. No way am I getting parts for this.
I went in and added gas to the push mower, which hasn't been started in about 3 years. Surely the machine gods owe me one favor here? Evidently not. Even after cleaning out the fuel bowl and spraying it with ether, I could only get it to run for about 5 seconds at a time. Carb needs pulled and cleaned or rebuilt.
So, back I go to the riding mower. Did I mention the grass is about 9 inches tall and it's supposed to rain in the next few hours? I took the mangled bits of idler pulley that were left into the garage, clamped them in a vice and sort of pathetically beat on them with a brass hammer until they resembled a tin foil replica of an idler pulley. I reinstalled them on the mower deck sandwiched between a couple of hardened washers there to keep the junk from just falling back apart. Realizing I now have a spinning pulley mounted between two stationary washers, I get out my oil can and shoot them liberally down with oil (Yeah...that should do it) and start up the mower. I made a run around the yard, and MIRACLE it seemed to work, so I told the wife to pray while she mowed and I went to the computer to order a replacement pulley.
Back to the Subaru. All the coolant was running out of the frame. There was none at all anywhere near the water pump or even the engine. I checked the radiator and it was fine. Looking at the overflow tank the level was above full. Best I could figure the coolant tank puked, possibly because of an air pocket left when I changed the timing belt a few weeks ago and had the radiator out. The squealing belt symptoms went away/returned by switching the a/c on or off. Off to the parts store and picked up both accessory belts for the car (the a/c belt is in back anyway behind the alternator belt). My youngest son helped me get the old belts off and new ones on and tensioned and everything was great for a test drive. Even let it sit running in the drive and it didn't leak any coolant, so I called that one fixed.
Tuesday I pulled my '65 mustang into the garage and pulled out the seats, as the upholstery guy needs them this week to recover. I've been waiting 10 weeks for him to call. Of course he waited until THIS WEEK to call.
Wednesday I got the mower parts and started in on it. But, the belt looked like **** so I didn't get it finished as the stores were all closed by then.
Thursday I got the new blower in for the kid's mustang. Installed it and put it back together. The a/c was cycling, so I checked the freon. Low, so I added a can and hope that keeps it going for the summer. Also got the new belt on the mower and buttoned it up.
So as of right this minute...I have nothing broken other than my pushmower. Not sure if I want to mess with it or not. What a week!
Oh wait...I'm still going to have to pull the dash on the mustang and actually replace that heater core too. GRRR. It never ends.
Phil
stimpy
troy twshp IL
my mower parts ( Bobcat t-20 ) are supposed to show up today , been almost a month waiting for them ( problem of owning a 1970's mower ) but the back up mower a 90's crapsman tractor is slowly dying ( trans failure )
pmiranda
Austin, TX
I suggest keeping a list of all the quick fixes you do, so you will remember to go back and do it right when you're not scrambling. Because the quick fixes always come apart at the least convenient times!
H
HoosierBuddy
Southern Indiana
You do know about the flow restrictor in the heater hose?
Yup, but it's obvious to me this is the original heater core. 27 years was all it was good for.
You know I bought my '65 in 1995, and it BLOWS MY MIND that the '89 is almost as old as the '65 was when I bought it. And...now that I think about it, the '65s heater core was leaking when I bought the car. It was accessible under the dash though. Probably took an hour. The fox is NOTORIOUS for being a PIA to change out, especially with AC. Most figure around 10 hours for the job.
BTW...Wife just called. Mower won't start. sigh.
Phil
RossABQ
NM
My son had a '94 Mustang that the heater core blew out twice. Finally got one to last a year. He was tired of the car, so I bought it. Within a month the core blew again.... I fixed it and sold it ASAP.
egnorant
East Texas
Sounds like a normal week here! Mine went, fuel pump, idler pulley (spindles, belt and blades while I'm there), flat on the trailer, Battery, battery again...then a cable, found the gas cap to the diesel mower that the 4 year old had hidden, drained diesel tank to remove rainwater, WiFi explodes and we drill 3/4 holes and buy 5/8 concrete anchors!
I know people that would kill for my problems!
Bruce
jask
Gods Country, B.C.
Thanks OP that put a smile on my face! "we are not laughing at you, we are laughing with you" ;)
I would still be tempted to do a compression on the WRX.. damn headgaskets can be flakey when they are going and it is not worth risking the bottom end if it dumps to oil.
DeaconSteve
NC, within driving distance to Raleigh
Yep, I have a broken down zero turn mower that I haven't gotten around to fix in a couple of months, but like Pa Kettle says "I'll get around to it one of these days". I also am having trouble getting a seat belt buckle for a 97 LaSabre. Seems all the surrounding year models have some slightly different style way of bolting them to the seat frame, or either I can't get the wrench to the bolt because the seat in the junker seat is in a position that makes it difficult to get to. But, the good news is, as far as I know, that is my biggest broke down messes I have.
SARG
Northeast
So you know you aren't alone:
Right now my diesel tractor loses power and I still have a field to mow down. Changed the fuel and air filters and she still won't hold rpms. Acts like a fuel issue but I haven't got it figured out ....and the ninty degree weather doesn't help.
Spent the morning trying to figure out why the power sliding door on the wife's Korean van won't open. Two years ago a cable broke & I finally found a new motor for less than $500. to install ... except now the door won't open so I'm stuck again.
KEH
1985 Ford LTD, the small LTD. Heater core a pain to change on it, had to take dash out.
Re SARG's diesel. Sometimes crud gets in the bottom of the tank. Flow is restricted but sometimes flows due to the motion of the tractor. A temporary but sometimes long term cure is to disconnect the fuel line, hopefully at a cut off valve at the tank. Take off fuel tank cap(very important). Blow a brief shot of compressed air into the tank. This will break up the blockage and redistribute the crud for a while. If that works, at some time you need to clean put the fuel tank. It should not be necessary to have the tank commercially cleaned out. If the diesel fuel bacteria is the problem(they make black gooey stuff) there are commercial treatments that you pour in the tank, probably found at auto parts stores. If that is the problem, the bacteria have to live in water in the fuel, so check your fuel chain.
KEH
SARG
Northeast
KEH .... Thanks for the info. The diesel tractor is a new Holland T1530 and the fuel tank on that model is a monster to get off. It was running OK and then it started to lose power and RPMs. The fuel filter bowl had no sediment at all in it. I had changed it about 5 hours ago on the clock along with the air filters. It is strange that when it all started acting up I filled the fuel tank to the brim with a quart of Lucas fuel treatment and it functioned as it should for about six acres of cutting. Then today I take it out and again ..... No power. Another mystery to work on.
KEH
SARG; Not familiar with that tractor. Hopefully the fuel tank cut off is at the very bottom of the tank in which can you can drain the fuel out(checking it for water) and then flush out the tank through the hole, after removing the cut off valve.Bear in mind there may be other issues such as electrical which I have no idea about. How old is the tractor?
KEH
SARG
Northeast
It's a 2012 with under 500 hours.
KEH
With no more hours than that the tractor should not be having problems. I still agree that fuel problems are possible. Any electronic fuel controls to cause problems?
KEH
SARG
Northeast
So today I decided to take a methodical approach and unhooked the fuel line from the filter assembly ..... got a good flow.
Then I checked the exit flow and it was just a trickle ........ so I removed the entire assembly and cleaned it all out with spray carb cleaner. Re-tested the flow after assembly and it was then good. I did not find what the obstruction was but did get her running again & finished cutting the field.
Now to try and figure out why the van door won't open. It probably is a bad sensor on the fuel door that prohibits the sliding door from opening. I suspect I'll need professional help to figure out the electronic ****.
KEH
Good news! Glad you got it going. You still might have crud in the tank, but lets not borry trouble.
Interesting problem: Mentioned your trouble to a relative. He said they once had similar problems in a Ford Dexta diesel that they had put a radiator cap on the fuel tank. The rad cap sealed the fuel tank and wouldn't let air in, creating a vacuum as fuel was used up. Of course, the proper cap solved the problem.
KEH
SARG
Northeast
KEH ... Just a follow up with more good news. A local wrench suggested the door was probably just "stuck". So this afternoon I got in the vehicle and did a shoulder bump with the inside handle pulled & sure enough the door popped open. I've now tore the interior apart and replaced the motor assembly. As I type the car is all back together and fully functional again. With two success stories in one week ............. I'll take the rest of the week off.
