reader2580
I am moving circuits from my main load center to a new sub panel that is fed by a generator transfer switch. Main panel is ITE Gould from 1980.
I almost couldn't get an old 20 amp breaker out of the main panel. It turned out there is a light layer of what looks like rust on the aluminum bus bar. The main wires coming into the box had not had duct seal installed and moisture probably got into the box. (It has duct seal now.) The bus bars are not pitted or corroded that I can tell. It doesn't look like some I have seen with most of the tab gone.
Do I need to replace the panel because of the minor corrosion? I would rather not due to all the work to replace it, but I also want to be safe. I am going to replace the old breakers. I already put in new AFCI breakers where required in 2014.
