Cleaning brass?
ekegelmann
Northville, Mi
I just bout a large grouping of torch heads, nozzles, etc. All brass antiques. What is the best way to polish up brass or to at least get the grime off etc? Like to make them look nice again. All ideas helpful and welcome.
Shiftless
East Bay SFO
Most any metal polish works great on brass. Mothers is popular for a good reason. Some guys like that wadding that comes in the blue can. Right now I am using Maas. Great stuff!
I got 2 big tubes free. Otherwise I might not have selected it at first because it is more expensive than most of the others. But a little goes a long way. Also great on smooth plastic.
Depending on the results you are expecting, try 0000 steel wool as a test to see if that is good enough. Faster and cheaper too. If yu want a mirror finish, you can start with the steel wool and then progress to a cream polish. Remember though... it is 4 ott.
kmacht
Connecticut
Another vote for brasso. Works really well to clean up almost any metal. You can usually find it in the grocery store.
Keith
#554
1950mercury
metro detroit
I use powdered citric acid (for canning vegetables) and an ultrasonic cleaner. 1 heaping tablespoon per quart of warm water. For all my ammo brass
Davefr
OR
Make sure you strip any previous lacquer or other coatings before you start polishing.
Motorman55
South Jersey
Nevr-Dull wadding is awesome.
I use Mothers if i need a compound.
Brasso (along with Kiwi boot polish) got kicked to the curb the day i was holding my DD214.
~Tejaas~
The Brasso wadding in the round cans made my USMC brass sparkle. I haven't been able to find the Brasso wadding anywhere by me. just the liquid polish.
Honda 1
Brasso is what was used in the Army. It always did a great job. Another terrific brand was Noxon,used by the building maintenance trades for items like door kick plates.
rhastings80
I have found bar keepers friend powder to work the fastest. Works on brass, copper and bronze. I use bar keepers friend first and then follow up with nevr-dull
EK - I've used and/or sold pretty much every product mentioned above.
But if you want to get it done fast: white vinegar and salt.
Rinse well after cleaning. Then buff it out with Simichrome, BlueMagic, Mother's, Never-Dull, whatever.
Anybody old enough to remember Fenton "Wheel Bright"? (same/same as Never-Dull)
Stay away from #0000 steel wool if you want mirror finish.
SantaAna12
Depends on the oxidation. I use Mothers as a compound too. Depending on your needs, it might be a single step application.
Waaaaaaaay faster than Brasso for cutting oxidation.
E
ekegelmann
Northville, Mi
So do i make a paste of the 2? Or let it soak for a certain period of time? How much salt vs vinegar? I use vinegar for rusted tools so.. may be the way I go..
Davefr
OR
There are four phases of restoring old brass:
1. First you need to clean off any grease, oil, lacquer or other contaminents/coatings on the surface of the brass. You need lacquer thinner, paint stripper or acetone to do this efficiently. If you try to do this with simichrome or brasso on previously coating brass you'll be polishing for a very, very long time.
2. Once your brass has nothing on it's surface you can remove the oxidation/tarnish/metal discoloration/etc. Phosphoric acid, Nitric acid, vineger/salt or lemon juice will do this much more effectively then metal polish. (toilet cleaner's often have phosphoric acid as the active ingredient)
3. Once you're down to a dull/consistent brass finish you can polish away to gradually bring up the luster. This is the phase where you use brasso/simichrome/etc. However a buffer works so much better along with cutting/polishing compounds. (Tripoli then red rouge works well).
4. Now you better think about protecting the finish or it'll revert back to where you started. Clear nitrocellulose lacquer like Nikkolas Clear coat works best on brass.
I collect fans and have spent tons of time restoring old brass.
crguy
SW Washington
He's talking about a torch & heads here. Who polishes stuff like that to a mirror finish? Who polishes a torch period?
Davefr
OR
Lots of collectors of vintage nozzles and torches:
EK: the vinegar and salt method is what we used to clean copper prior to baking glass enamel onto it. also used for cloisonné work.
proportions are: whatever works. I just pour a little vinegar into a glass, pour in a little salt - and wet a rag in it and wipe down whatever object I'm working on. there's no "magic formula" as far as mixing. sometimes I'll wet the object with vinegar, sprinkle salt on the rag, and then wipe it down.
as Dave mentioned above: you have to put something on to prevent it from oxidizing - either buff it out with one of those polishes - most of which will leave a "protective coating" - or spray it with something (as Dave mentioned.)
I've been using Wright's Silver Polish lately because I ran out of Simichrome - all of those brands will work - some work better than others. A buddy of mine swears by some high-priced German brand - says it worked faster buffing the chrome on his Sportster - can't recall the brand.
