27 gallon Craftsman Professional Air Compressor ?
gdocktor3
Connecticut
1.9 hp is pretty weak, no? I have an older 30 gallon craftsman with a 5hp motor and it fills my tank rather quickly, but more importantly it will keep up with my tools even when the tank is low. Seems a bit expensive in my opinion.
Also, I didn't have 220 in my garage so I bought a roll of 12-2 wire, ran it along the wall where dish network ran their wire for my old dish, and installed a 30 amp breaker in my panel. It's not a nice and neat, professional looking job, but I've got the power I need.
Voi
Western South Dakota
I had the horizontal version and got tired of the space it took up and traded it to a friend. That was at least ten years ago and it's still running strong for him. It is a Devilbiss made compressor. Might see if you can figure out who makes the vertical Craftsman nowadays. There used to be websites where you could look up manufacturer with serial or product numbers.
The 26 gallon vertical re-branded by Napa, Belaire and Chicago Pneumatic gets really good reviews. I'd look up and see if your local Napa has one and what the current MSRP is before you buy the Craftsman. Supposed to be very quiet.
Others have suggested that for the same money one should consider a similar sized compressor from Harbor Freight. Put the money saved into a noise dampening cabinet of some sort if the noise bothers you.
I believe Harbor Freight carries both oil-lubed and oil-less compressors in that size range.
psychoclaw84
Valley of the Sun
I agree with the 26 gallon vertical compressor, bought a NAPA compressor and it is quiet as compressors goes and worth every penny.
md21722
Mt Juliet, TN
NAPA usually runs compressor sales in Q2 and Q4. I had the 26 gallon unit. Its made by ABAC same as the Quincy and Chicago Pneumatic. The only difference is the paint color. Will not trip a 15A breaker.
The size you are looking at is all you need for basic impact and tire filling.
Not sure about the Craftsman, but if its sized for what you want then it may be just fine.
As far as the 5HP goes, some time ago the numbers were inflated to include the peak or start windings in the HP calculations. If its 120V there is no way it is a real 5HP. If it is a true 5HP motor, it should be on #8 Romex or #10 THHN. I am guessing yours is a 3HP that's labeled a 5HP and probably puts out 10 CFM @ 90PSI. By code even that should be on #10 Romex or #12 THHN. 2HP is the largest you can get at 120V and true 2HP compressors/motors generally require a 20A circuit. The two I had would trip 15A breakers all day long. For what they were, they were great but I needed more air.
The one thing that is always poopy with these portable single stage is the pressures they run at. You've got to figure in a 20 psi pressure drop through the fittings and hose to your tool. So they really should cut in no sooner than 110 psi otherwise the tool isn't getting the air it needs. When I had the NAPA I always noticed the air ratchet wouldn't loosen bolts if tank pressure was just before the compressor kicked in. If it had just filled up it would work great. The Condor and Square D pressure regulators are adjustable, but the Furnas ones are not.
Showkey
"MEMBER EMERITUS"
Wausau WI
5.8 cfm at 90 psi.............they are calling it professional ????
27 gallon tank is good.........
Two Door
Houston, TX - USA
This compressor is a Sanborn (formerly Coleman) Black Max. Nothing wrong with the quality, if it fits your needs.
I have one and it is very quiet. Much more so than my old Sears Devillbiss.
PBCampbell
WV
Everyone has 240 volts accessible, it's what serves your house. Two legs of 120 volts each. Unless you have a need for portability you'd be better served with a stationary compressor of at least 3 hp. The cost for much better performance isn't much more.
sberry
Brethren, Michigan
This is so true. Especially in regards to cost.
sberry
Brethren, Michigan
But especially given new tool improvements I can see getting along in suburbia with the 27 gallon thing though. I got friends with them and they get along. A new battery impact is cheaper than air now and if a guy isn't blasting and running body tools it fills the chores.
The tank helps but the circuit is so poor, really needs its own wire anyway, just ae easy 240 and a better pump is worth 100 more for 2x or more as good.
Part of this equation I spose is if one wants it on 24/7, I personally use it like electric or more like water. If a guy is willing to run it as one thing at a time then most of this babble is moot.
BDT/NWMN
Erskine, Mn
Might apply a bit of name-fixen to that ad... Call that one : "Craftsman's Better Choice Homeowner Compressor"
Twin cylinder, two stage, cast iron pumps are my personal choice,, but I believe that compressor would satisfy most homeowners needs without problems..
md21722
Mt Juliet, TN
In my experience a 1.5-2 HP 26-30 gallon compressor will generally do as much as a 3 HP 60 gallon. My first air compressor was a 3HP 60 gallon. When I moved and lost 220V in the garage, I sold it and replace it later with a 2HP 26 gallon. I couldn't tell the difference except the compressor would run a little more often. Big deal. Past basic impact, ratchet, and tire filling, you need to be looking at a 5, 7.5, or 10 HP dual stage. I'm talking if you only have one. I realize there are special cases where a 3 HP may be helpful as an auxiliary source or may fit some specific needs, but I haven't found one. As my air demands increased I upgraded from a single 26-30 gallon to 3 of them (bought cheap) but always struggled and the noise was another issue. Today I run 2 x 5 HP Champion R series with air storage at 180 gallons. For basic use I can go a while before the compressor will kick on. If I'm using air hungry tools they both run and keep up. The slow speed the Champions run at is easy on the ears. If the compressors are in a separate room noise wouldn't be an issue. We have guys on here running pancake compressors, others making duplex 7.5 HP compressors, and others who work at factories or plants where there is "unlimited air" so this forum cover a wide spectrum.
C
Cruzomatic
San Antonio, Tx
Not sure how I would go about doing that other than hiring an electrician.
sberry
Brethren, Michigan
This is probably true. I was trying to rationalize how a bit more pump may help but probably not all that much for most people that were not trying to blast and blow off large equipment.
Voi
I'll stop in a Napa Auto Parts soon to check out their compressor soon.
82-4253-PAT is the one you're looking for. I believe they also sell a 26 gallon horizontal that doesn't produce quite as much air as the vertical.
7.4 CFM at 90 PSI compared to 5.8 CFM at 90 PSI for the Craftsman as mentioned in post #6.
C
Cruzomatic
San Antonio, Tx
Thank You...appreciate the chime in.
md21722
Mt Juliet, TN
In my experience the difference between 5.8 and 7.4 will not be noticeable and both may actually have the same output. Craftsman probably rates in SCFM. ABAC rates in ACFM. Looking back in my notes, my old Campbell Hausfeld 6.4 SCFM @ 90PSI was the same as or slightly better than the NAPA rated 7.4 ACFM @ 90PSI. Having said that, the NAPA is a nicely constructed unit and uses a copper line rather than aluminum. The Craftsman may have better wheels.
bubinga
That all being said I think mine's about a 25-gallon probably an overinflated 3 horsepower says but it's no 3 horsepower I think it I think it pulls about I don't know I'm just guessing 10 amps but for what I do run an impact and stuff in it that's fine
Sent from my MotoG3 using Tapatalk
bubinga
PB Campbell
Wiring up a 220 outlet and installing a breaker is pretty basic someone on here walk you through it I would say if you know enough to be working on your own car and you know enough to install breaker there's nothing to it basically common sense and good judgment plus a little bit of code you know not saying I would get a permit and have an expected to either but I think you can handle it
