Storing kayaks?
jake00
illinois -- NW Burbs
I've got 2 10ft kayaks that I need to store. I'm thinking of a strap and pulley system mounted on the garage ceiling.
Anyone got and slick ideas?
rayra
Escaped from Los Angeles
That IS the 'slick idea'.
The other is add some stanchions projecting out from your wall studs and put them up high on the wall (upside down) like a lumber rack.
NUTTSGT
Northern Central Ohio
The pulley system is what of one of the guys at work does. Some how he has them cabled together to prevent their theft also.
LS6 Tommy
Northern NJ
I can't help much from personal experience. All 3 of my boats stay locked to the racks at the lake all year round. I have thought about the pulley systems because if I wanted to keep them at home in the off season I could lift them all the way up past the joists in the garage and they would be completely out of the way.
Tommy
MDSPHOTO
Oz
Yep the pulley system is the way to go. We have our 14' attached to the basement rafters.
goofiefoot
Rockport, TX
Eye screws in the rafters, s-hooks, chain and pool noodles keep my 14.5 Native close to the ceiling and stores paddles, seats and fishing box.
Voi
Western South Dakota
From another thread:
http://www.garagejournal.com/forum/showpost.php?p=5678727&postcount=18
PCustoms
VT
I spanned a 2x4 between the I joists (slip in @ angle and then twist to sit on the flange) at my apartment and screw a big hook into the center.
Walk in with kayak, place 1 end on ground and hook opposite handle to ceiling. Lift and hook other end. Simole, cost $4 to hang 2 boats.
teamextreme
Lakewood, CO
I did what PattenP did except I used bent pieces of EMT and covered it in plumbing pipe insulation. I've also hung them from the ceiling. I don't bother with a pulley system, I just use a 2x4 on edge, covered with carpet, with eye bolts on the ends. I then use motorcycle tie-downs to lift it up, doing one corner a foot or so at a time until it's up against the ceiling, then secure it with short lengths of chain.
Heavy Metal Doctor
Mason Dixon Line
We have the 16' canoe hung by 2 ratcheting rope pulleys - the kind they sell as deer field dressing hangers that have a small release line to allow you to let them back down.
The kids 2 10' Kayaks are on L brackets made out of 2x4's and some plywood gussets.
Just purchased 2 more 12' Kayaks, so it' time to make more space for them.....
