Above 1200 Sq/FT Casa de Frijolee - SoCal to Hawaii - gear head style
F
frijolee
Big Island, HI
Re: Casa de Frijolee - a Gear Head's 2-car garage
Back to the garage:
Finally have things just about cleaned up and painted. Here's how it went down. I had picked up 3 gallons of nice Dunn Edwards paint in a pretty medium taupe color at a garage sale for $20. I was thinking I could use it for the bottom section of a two tone.
A few reference pics of the general effect I was going for...
Well, went to break out the paint and found it was a lot more tan than I remembered. Too dark to be the top section and too light to be the bottom. I did use it in the entry hallway as is though. My 4 year old helping out. Maybe somewhere in the latte spectrum?
Dragged a gallon over to Home Depot to see if we could tint it further (nope, they don't tint outside paint). They could however sell me water based paint that I could mix my own, so I decided to blow an extra $8 on a quart of black and give it a shot. Ended up using my garage sale paint as the base color and adding white up top AND black on the bottom. My sister and her family were in town (kinda a big deal since they live in Kenya), so had some more little helpers as well. Nephew working on the gray I mixed up. Kid was STOKED to be helping.
The mess always gets worse before it gets better, but at least the walls are coming along. Big *** sheet of carbon fiber peeking out that might be cabinet door someday.
Once I had that roughed in it was time for the stripe. I didn't want something super loud so I used some of the same hammer finish bronze I've use a few other projects and was pretty happy with that. Just enough interest when you look at it up close, simply and classy from afar. Bronze seems to work with my crazy floor anyways.
Couple tips on painting stripes... It'll try to run under your tape a bit so there are two methods I found online to compensate (I'd give props to the appropriate folks on pinterest but I can't remember exactly where I read these). First you can paint the edges in your base color BEFORE painting the strip to seal the seam. You have to wait for that to dry however, so I used option 2: for your first coat painting the stripe do it was a super dry brush so it's thin thin thin and doesn't have any appreciable volume to wick under the edge. I did a dry coat and two heavier, working ended to end in continuous laps.
Pull the tape before the paint fully dries. Bingo, nice crisp lines.
Oh and just in case I ever need to mix more, I did my mixing with relatively precise ratios so I could repeat down the road if it comes to it. Had a fun little science experiement with all the kids on volumes and ratios to pick the colors.
Winning ratios were 1:12 white and 4:1 black. Since they're all based upon the same tan paint as a base they're naturally complementary. :cool:
Solid! and cheap... which is a double win in my book.
-Joel
F
frijolee
Big Island, HI
Material Rack
Got the hair brained idea to build some material racking that could tuck into the 1 ft or so recess between wall and garage door tracks. Seems like I'm always tripping over bar stock and some of it was a) too long to just lean against a corner and b) needed a better home than outside on a slab in the weather.
I say hair brained because it took way more work than I realized, and I probably should have looked longer and found something off the shelf... but like most projects I can only say that with the benefit of hindsight, and hey, it's a nice place to work right?
Again, inspiration:
This needed to be mounted up high to the studs so I could still open car doors and work. Short cantilevers since I don't have much depth to work in.
Started from bar stock and plate:
Test fitting and working out the spacing (5 deg upslope for each bar, slight stagger top to bottom, lowest is a shorty so I don't smack my head)
Cut a lot:
Cut more, round edges, deburr, sandblast mill scale, etc:
Make sure they're clocked right since everything was cut at angles:
Get pissed when you tack all the end caps upside down (sigh), then break em all and do it the right way.
Weld for days... I'm building 8 of these, times 5 bars, times 2 ends, times 90 degree passes (4 per end). Wait I have 320 welds to do? Dammit!
Not shown...
-Chip the splatter because I used the MIG for all in favor of speed.
-Ask for a huge favor and have a bud powder coat them red (one at a time since they're pretty much too long for his oven).
-Leave them in the attic while you ship overseas for a few months.
-Finish your painting because once these are up they're never moving...
And finally...
...end up with something pretty bitchin' that fits the space.
-Joel
F
frijolee
Big Island, HI
Thanks, ironically since making the space nicer I've been making a proper mess with pretty high regularity.
F
frijolee
Big Island, HI
One more paint shot...
I did end up using the L trim I mentioned a while back on the door frame.
That's all mudded in, so you don't see it. I did get a little creative wrapping the stripe around it to help with some delineation.
rattle_snake
Chandler, AZ
Material rack is freaking sweet. Nice job. Now I'm not as happy with mine. damn you.
F
frijolee
Big Island, HI
Ha! I can't even tell you how many times that's happened to me while looking around garage journal. Got a link to what you did?
Bib Overalls
Jonesboro, Arkansas
Nice rack. :eek:
I have something similar but no where near as capacious. My problem is pieces from 4" to 3' in length. I save just about every scrap of metal I can.
F
frijolee
Big Island, HI
Nice rack. :eek:
A cunning linguist in the group.
Capacious = serious $0.50 word of the day. Nice!
Part of the reason I made 8 of these was so that the majority could be on every stud at 16" centers helps keep the random scrap bin smaller. I also have a hard time throwing away metal.
F
frijolee
Big Island, HI
Minor point on the "if I had to do it over again front":
If you're daisy chaining a few standard outlets from a single GFI outlet for protection (allowed by code). Get the square form factor outlets to match the GFI.
Finding the correct wall plate ended up being a bit of a headache.
1) Had seen the blended style at Home Depot so I assumed they were readily available in different finishes (nope only white plastic).
2) Didn't know these things were called "wall plates" but once I found that out I still had 982,591 options to dig between on amazon (not joking, that's a real number).
3) Finally tracked down the proper names so I could order what I wanted (standard dual smiley is a "duplex", square form factor is "decora").
So with that in hand I could search for a "2 gang, 1 duplex, 1 decora, brushed stainless wall plate" and find what I needed. Then overpay for it since it's a oddball (ok, wasn't that bad but $9 for a two pack was still more than normal) and THEN wait 1.5 weeks to arrive .
OR if I known what I was doing up front I could have just bought all my regular sockets in the decora form factor and been done with it. So there you go.
jbmatth
Northern Ok.
I love it when I run accross something like that. I know exactly what I'm looking for but no one seems to make it no matter how hard I search. Looking good, keep the updates coming.
JB
F
frijolee
Big Island, HI
Ha! That's a different way of looking at it for sure.
Garage updates will likely slow down a bit. I'm going to be jumping back into the car projects here pretty soon, but I'll see if I can't get a few cleaned up glamour shots of the overall before I make a massive mess of things again.
Or heck, do you guys like seeing massive mess/ car projects in work shots? That I should be able to throw up from time to time.
I do have a few garage ideas left but I again, some other things are going to take priority first.
-Joel
jbmatth
Northern Ok.
I'd have to say yes, I like seeing garages used be that perfect show garages or some like my old barn that has been used and abused for years. I used to have a 1991 RX-7 and really like your car so please do share some of it with us.
JB
F
frijolee
Big Island, HI
Did a small upgrade on the power front for my workbench.
Back when I'd installed one of the HF 4' strips on my toolbox.
I'd always planned to do something similar with my workbench and had planned out the spacing of the uprights the hold the shelf in order to compensate (and that was what? more than year ago?) Anyways, cord for the strip kinda came out the wrong end but I had some plastic "P" clips that worked pretty well for a re-route.
Mounting is countersunk.
I also swapped over all hardware on the back splash from zinc plated to powdercoat. Galvanic corrosion hadn't been an issue thus far but there is a washer/dryer in there so I figured better safe than sorry since I'd picked up some stainless for another project recently.
Spent a bunch of time over the weekend getting organized. Need to do a quick alignment on the wife's car, but I'm getting ready to pull in my FJ40. Almost there... You can see the new power strip peaking out in the back.
F
frijolee
Big Island, HI
Small one today...
The peak of the garage is offset vs. actual garage floorpan...
A while back I'd knocked out the drywall that closed off the space above our entry walkway (before the garage attic went in).
It turned into a pretty nice bonus storage area up there so I can tuck stuff under the eaves... like my children for instance.
Problem was that I no longer had a drywall barrier to the proper attic. This would be an issue for firecode and insurance if I ever burn my house down. It also meant the garage to house door would slam if we were running the whole house fan. That fan blows into the attic, if the door between house and garage is open it can form a high flow loop and the door slams shut with however much velocity it can built up.
However, it was nice having better access to the proper attic than through the tiny hole in my closet so I built a door using plywood sheathed with 5/8" firecore drywall.
Latch I had lying around to keep it closed. That's a piece of 2" header tubing to make trim by the way.
Brass sailboat cleat made a decent handle. There's a pin in the rafters that holds the door open if I want access.
So now my door house to garage door doesn't slam, I still have decent attic access, and I made a good faith effort to align to firecode. The things we do in the name of storage ehh?
xtremek
St. Johns, Mi
It turned into a pretty nice bonus storage area up there so I can tuck stuff under the eaves... like my children for instance.......So now my door house to garage door doesn't slam, I still have decent attic access, and I made a good faith effort to align to firecode. The things we do in the name of storage ehh?
I like your child storage unit, do you have to duct tape their mouths to keep them quiet when you leave them up there?:lol_hitti And that's a very creative solution for the attic door, very cool.:thumbup::beer:
Pay2play
Great space Joel! Loved reading through your projects. I wish I had your fab skills.
F
frijolee
Big Island, HI
I like your child storage unit.
When they're up in the attic that generally means they're helping Daddy. Even though kid help sometimes slows things down vs. working solo, it sure makes you feel less guilty about ditching the family when you can hang and work at the same time.
Thanks. I do OK. For what it's worth this healthy reminder showed up in my FB newsfeed this morning and made me smile.
Just a T shirt ad (not pointed at me, or you guys for that matter), but it still cracked me up. :D If you want to be inspired (and disheartened at the same time), you can follow WeldPorn on social media... No affiliation, they're just amazing.
-Joel
jbmatth
Northern Ok.
Thanks for the tip from the shirt, I now feel completely inadaquate. :)
JB
F
frijolee
Big Island, HI
Had things mostly cleaned up so I took an overview shot.
Before rolling in the new inhabitant.
I'd thought I was about ready to start structure additions on the FJ.
Nope.
Unfortunately I managed to snap my track bar bracket on the XJ when the front locker stayed engaged flipping a U turn on the street (had the wife driving in 4L). It didn't disengage even though I'd shifted out when I jumped in to flip the U. I heard the tires chirp once but I figured it'd just drive through it. Then BANG!! Thought I'd blown an axle shaft at first.
Criss crossed straps got it back in the driveway as above.
One more thing to fix, but sooooo thankful this didn't happen at speed. Looks like the good Lord must not be through with me yet.
-Joel
Pay2play
Glad you and your family are safe! Looking forward to the FJ build. It already looks quite capable! Hope you keep us updated here.
F
frijolee
Big Island, HI
Re: FJ40. It'll be more capable when it has a radiator, fuel system, steering, pedals, and umm, floorboards. Yeah, that'd be a good idea too.
(Long way to go).
Pay2play
Minor details...[emoji12]
onemanarmy
Raleigh, NC
4 low on pavement?
whats the drivetrain in the 40? Those look like EXTRA full width axles.
F
frijolee
Big Island, HI
4 low on pavement?
Kinda yes to 4L on pavement. Front diff hadn't disengaged even though I shifted back to 2 Hi.
D60 front, 14B rear. 82" to outside of tires. Probably looks extra wide because the shocks are collapsed all the way in the above (but possibly that's the only way this'll go into the garage). Here's ride height.
-Joel
F
frijolee
Big Island, HI
Well hell...
It's been a bit. Figured it was time to update all my build threads...
Garage stuff: Well my work closed about a month ago so I'm now in the midst of a job hunt and cranking away on the projects like crazy. The good news so I dragged home a metric ton of randomness they were giving away and the garage went full cluster f--- mode.
Don't you need a dozen or so rolls of edge trim? Of course you do.
Yeah, nightmare... Good stuff, but nightmare to stumble around.
This was me sorting just the bins of electrical goodies and hoses...
There's a shed in work, but I'll have to get back to that...
F
frijolee
Big Island, HI
I actually wanted to take a sidebar and post a bit about the backyard. When you have a garage as small as mine sometimes overflow spaces become pretty handy. When there was a distinct possibility I'd move with my former company to Georgia (later decided no) I decided I needed to finish my backyard area. We'd poured some concrete slabs a while back for RV access, not that I have an RV, but I wanted to build a deck and planter to handle the elevation changes to the fence and make the area a bit nicer.
Rough layout when there was nothing there:
It was a long run so I kind of had a stair stepping design in my head.
Bought a bunch of pressure treated 4x4s for the uprights and cut to length.
Didn't get picture of the rental auger for dig post holes but that was fun. Top and bottom cuts were coated with Henry's Roofing Tar for extra moisture/bug resistance.
Gardener friend came and worked like a dog for a few days digging and pouring concrete. He's bad *** but I don't know how he makes a living at the rates he charges. I try to at least buy lunch and tip him well. I also want to work along side rather than just pay him to go do.
We did buff the fog out of his Tacoma headlights one evening as an extra thank you.
Home depot delivers late...
Random treasure found while digging in the back yard. Note the spark plug and brake shoes. Is that a part of a carburetor? Someone was truly a backyard mechanical at some point.
Gravel delivery on the RV slab and making use of my removable fence section.
Digging down to prep for the deck. I'm putting this at ground level which is a little unconventional but I think will be cool when I'm done.
"Natural" stain in a clear is actually mustard yellow. That won't look right on redwood so back it goes.
Redwood with redwood stain. Much better.
Lumber going back because it was warped. Learned my lesson. Always order extra and just plan to return some.
Fresh extra long pieces getting delivered. Serious, why does Home Depot always deliver after dark? RX7 getting driven though and that makes me happy.
Girls love the Home Depot carts. How many times can you visit the store in a week?
A bunch of the new stuff is warped too. Dammit. Looks like I'm heading for Ganahl and paying top dollar to pick out my own. Note to self. Stick to Home Depot standard size heart redwood where you can.
Didn't get any pictures of the work party but one of my best friends from growing up came down and the two of us slaved for a weekend to get the back structure of the deck laid in. You can see it peaking out at left.
More to come.
-Joel
F
frijolee
Big Island, HI
So somewhere along this point, it's about a month from my office closure. We decided we'd try NOT to move if we could avoid it. However that leaves me kicking myself wondering why I'm elbows deep remodeling the back yard when I should be hunting for a job. Well, I am hunting for a job all along here, but it's not a sole focus.
Eventually I decide that if all I do is sit in front of a screen and write cover letters I'll go mad and that physical exertion and making something with my hands is good for my head and heart so it's not such a bad move. Besides, there's still the outside possibility that a new job will require a move and having a finished backyard would be a good call if it came to that. Same logic for my Land Cruiser. It's OK to keep working on that, because if I HAD to sell it the investment would pay returns.
Anyways, that mini mountain of dirt above. That's about half of what I pulled out of my backyard. The other half was already in the lowboy dumpster I rented.
Pro tip on dumpsters. I didn't realize how expensive these were. It's a touch north of $700 for a "mixed load." However if you're only removing "clean fill dirt" the trash company can sell or re-use it so that dropped my cost to $325. I tried to post free dirt on craigslist and and got zero bites in a week so I pulled the trigger on the rental. By the way, there are a LOT of folks posting free dirt on craigslist so if you need some, go there first.
Two evenings and about 6 hours later (ground was already broken up so I was just moving a pile)
Best guess I moved 7 yards of dirt. Something like 60 wheelbarrow loads (I could do one about every 6 minutes). I was just happy that I could go shovel for hours and not die. Apparently I'm still in OK shape.
What might not be obvious from structure pic above is all the weird angles I'm using in this deck. The area in question is a triangular so the deck needs to bend about 45 and then flare wider as it approach my patio slab. I also had to get creative with the flange hangers since they're only made to work at 90 degree angles. Two layers of wood (overlapping) wasn't a good option since I had to dig down whatever thickness of structure I was using.
Here's what I came up with.
1) You start by bending the acute angle on the flange hanger to land flush with whatever joist you're playing with.
2) Start the toe screws so this side is flush as intended (stainless is best for pressure treated lumber, hot dip galvanized is OK, basic Zinc screws will die quickly)
3) The opposite site you have to twist and pull so at least the tip is flush.
4) From there it's not too bad to hammer form the hanger to better meet the obtuse angle and install relatively normally.
I also bough a Kreig mini pocket hole drill fixture. I'm in love with this thing.
Made short work of some little kickers for lateral support. Here's one that twisted as it was drying so I fought it back to square during install and figured the stress would relax as it dried further.
So what's all the fuss about?
The joists run RADIALLY as the deck flares. ;) Should give it a cool looking screw pattern when I'm done.
-Joel
racestatus
Danbury, CT
backyard is coming along!! home depot is nothing but trash! I would sling 2x4s to the side to find 1 straight on and they would get mad at me. I simply told them to find better suppliers. now I use lowes they seem to have better wood
F
frijolee
Big Island, HI
Next step... Thought twice about having the low spot in the yard be under the deck. Even with as little rain as So Cal gets and even if I filled the underside with gravel, I was concerned it could turn into a pool. So I decided to up the complexity and add drains.
It zigzags under the structure. Three drain points, all sloping downhill (but not by much)
Until eventually it cuts between my planter pools and the RV slab.
This trench was a solid 20 inches deep. My folks were in town so I recruited them to help. Thanks Mom and Pop!
Then the real fun, breaking through the block wall. I refused to be denied but I had about 4 hours into making this hole.
Someone tell me if there's a better way. The big rental core drill home depot has don't look like they work horizontally and I was just above a curb on the far side (which conveniently is a drainage way).
Anyways, tidied up the result and I think I've done everything I could to keep this happy long term despite the ground level install.
Thoughts? Total overkill or just about right?
F
frijolee
Big Island, HI
I really want to get back to posting about the garage and car projects but figured I should stay the course and catch up on this first.
I'd already stained the backsides, but the real faces got sanded first! Not shown, belt sander after the palm jobbie was too slow.
Gravel burrito of weed clothe behind to help drainage. Even with real wood I want this to last a long long time.
End detail where the elevation changes on the rest of my yard. Every board got installed with 3/32 spacers to ensure equal the wood had even gaps for swelling. Still not perfect, but wood is an imperfect media and it's close.
Complete gravel burrito.
Plastic shims on the top surface where my poles weren't prefect.
And planters done.
Now I throw some mulch in there and ignore it. You guys are probably only interested in the build part anyways. ;-) Eventually Ill post a shot of the completed deck, but that's just a matter of screwing down the decking.
Sidebar, done. It's back to the garage after this I promise.
Joel
tennesseewj
Knoxville, TN
I had to binge-read this entire thread after stumbling across it. Great progress - keep it up!
Sent from my Pixel using Tapatalk
abovo
Thank you for posting these projects. I am also in Orange County and have been planning a 200A panel upgrade with a 100A garage subpanel. Unfortunately my wire is direct bury and only good for 125A so I'll be doing some trenching.
For your redwood you sanded with something like a 120 grit and applied a redwood stain? Is there any poly on it? I am building a pool enclosure and a fence this summer out of redwood and like the look of your planters.
xtremek
St. Johns, Mi
For most of us, the yard is just an extension of our garage. And build techniques transfer from one type of structure to another. So keep posting the backyard stuff, it is appreciated.
F
frijolee
Big Island, HI
Bummer on the digging. It's worth it though. Power has been the best thing I've done in the garage by far.
Belt sander was 60 grit, I think I was using 100 or 120 on the palm and it felt about right. Mostly I wanted them cleaned so the stain would go on even. Stain is Behr Premium Transparent Weatherproofing. I didn't go crazy here as locally available by a big brand was more important to me than whatever is the gnarliest craziest un-obtainium. A deck I'll have to recoat, my garage floor was intended to be one and done.
Thanks. I've been enjoying building and one does flow to the other. Most recently it's been my side yard where I keep my industrial **** which brings me to....
F
frijolee
Big Island, HI
Just when I thought I was done with organizing freebies.
MillenWorks (my old job) gave away all their rem stock metals.
Holy ****! That's a lot of steel. I brought home enough to well cover my driveway and I barely dented the net.
Dom (anyone making rock sliders need some?) plus some aluminum.
Full sheets, some of them virgin.
Drops from the water jet table. This stack is about a foot deep.
Stainless (oh baby do I have some fuel hardlines in my future!)
Material cart (I bought this one) should be a huge help.
Welded shelving, I'll figure out something for this.
Stupid heavy racking.
Stupid heavy casters on a 4x4x0.25 backbone.
And this is what you look like after a day in the sun hauling free metal. Yes, I'm dumb for wearing white. Yes, I did it on purpose because I'm also a f---ing gringo and asphalt is hot enough without a dark shirt. Took three trailer loads to get it home. With many thanks to my friend Anthony who at least got himself a great deal on a bitching shear for his trouble.
Thar be mischief afoot mi hearties! ;)
jbmatth
Northern Ok.
Holy Cow that is a great score! The first thought that came to mind was how on earth are you going to find a place to store all of that? Looking forward to seeing more projects come out of the garage.
JB
zmotorsports
Northern Utah
The yard is looking good.
Great score on all of the stock, color me jealous.:beer:
I am looking forward to seeing progress on the FJ.
Mike
