Will acetone remove chrome from sockets?
rjohnson
Marengo, Illinois
Hi everyone,
I have some dirty old Bonney sockets sitting in WD-40 trying to get dirt and grime off inside. Would it damage the chrome if I put it in acetone?
Thanks,
Richard
johnnyturbo
Cleveland Ohio area
If you want to clean up the chrome, use coca-cola and aluminum foil. As a kid, my Mom taught me that trick to clean up rusty bicycle rims. I just poured the coke in a bowl and used a piece of aluminum foil as a scrub pad. Coke and a dobe pad might work as well. I've been told that if you put a nail in a glass of coke, it will be gone in a week or less. I drink water.
pipehack
chicago
If it was possible to have a glass of stomach acid. Put a 16 penny nail in that, it will be gone in less than 12 hours. That's a lot of hype about how bad pop is for you. In fact diet pop is the worse thing you can drink. Did you try using a crappy socket in acetone???
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Acetone will not damage the chrome. It is just a hydrocarbon solvent.
The aluminum foil and coke or vinegar trick works to remove rust stains from the chromed surface due to a chemical reaction with the aluminum foil. The coke or vinegar just provides a slightly acidic transfer liquid. Vinegar smells worse but it is not as sticky as coke.
ddawg16
S. California
Avoid the vinegar.....it will really pit the metal......
I prefer the phosphoric acid....you can buy it at HD.
When finished with it.....just pour down the drain while diluting it with the tap water....won't hurt a thing...
Steevo
43.49600, -112.04300
If they are just dirty/caked with grease/cruddy, then soak them in a good de-greaser for a day or so, and then (when the wife isn't home) slip them over the wire posts in the dishwasher with the socket side down, and put it on potscrubber cycle.
Shiny-clean!!!
Just check thoroughly for grease smears in the DW before wifey sees it.
DAMHIK!!
redsky49
near the coast in eastern North Carolina
Shiny-clean!!!
DAMHIK!!
But avoid the dry cycle to prevent rusting of worn components :thumbup:
NeilH
UK
i second the comment about the use of coca cola.
also, the comment about diet coke by pipehack.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Vinegar will not pit the metal any worse than phosphoric acid. It is much weaker. Any pits in the metal come from the original amount of rust on the metal surface that was removed by the chemical reaction. Vinegar can be found in most kitchens. No special precautions or dilution is required with vinegar.
-B-
Northshore of Boston
Avoid the acetone it is a carcinogen gen that travels though you body via skin contact and vapors it is vile use anything else. carb cleaner or starting fluid work rel well for stubborn old grease and oil.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
z28toz06
Connecticut
if you are a shooter and reload your own ammo, just dump them in your vibratory tumbler and they will come out amazing!
Jononon
I find an overnight soak in kerosene gets the **** off, then washing up liquid and a toothbrush, then a squirt of WD40. Nothing (too) hazardous, no risk of upsetting the missus. No help with pre-existing rust, of course.
If you think acetone is bad check out the stuff in carb cleaner.
:thumbup:
Plus carb cleaner is 30% acetone anyway.
stewart
long island NY
Hi everyone,
Thanks,
Richard
Hello
The best wat to keep tools clean is to use them, of course this will wear off the chrome, I quess it's a catch 22 situation! The W-D is a pretty good cleaner for old petro chemicals or try diesel fuel. For rust maybe nevr-dull then clean in acetone and spray with clear lacquer or they will rust again.
Stewart
Elroy
kentucky
What you may find however is that most "thinners" will remove the silver paint that most sockets have applied to the inner broach.
This maybe a non-issue for a vintage Bonney but almost all newer sockets have this silver paint on the inside.
Acetone will have zero effect on the chrome.
Mike83
Wisconsin
Will carb cleaner work to remove my toenail polish, though? :confused:
Uncle Buck
Kansas
I totally agree with what George Jetsons son here said about the removal of silver paint. :lol_hitti
z28snksknr
Turnersville, NJ
Plain old engine degreaser always worked well for me. Let em sit and rinse them off.
If WD-40 and Enginer degreaser doesn't work, it's not petroleum based grime. If so, try alcohol. Usually between pretroleum based solvents or alcohol based solvents you're gonna dissolve the majority of substances (that are readily found in a garage).
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Just toss the sockets in the wifes dishwasher.:lol_hitti
You could soak them in a bucket of Dawn dishwashing liquid mixed up rather strong. Dawn cuts grease really well.
hydramatic
Alabama
how about mineral spirits and a brush. then a light buff with a jeweler`s buffing pad, and some green rouge..
njfl
Neptune, NJ
I was surprised that no one mentioned brake cleaner in this thread. When you guys are talking about acetone, I assume that you mean nail polish remover type acetone or acetone that you buy in volume from an auto supplier, right?
I have always found brake cleaner to be the best for cleaning dirt, grease and everything from many materials without leaving residue. Brake cleaner uses acetone as the carrier and as such it makes up typically 50% by volume. The other 50% is other solvents that do a nice job cleaning, instantly, with no soaking necessary.
You can get brake cleaner super cheap in cans at Auto Zone as they often have their house brand on sale.
Brake cleaner will not harm chrome either. It will mess up the silver painted surfaces that you are talking about in some of these posts though.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
But it will corrode the inside of the sockets if they are left in the solution too long or they are not rinsed thoroughly. It is real hard on skin also.
