Older 2 post rotary lift???
mustangmanny
Broomall, Pa.
Hey guys I was hoping someone could help me on how to remove the hydraulic rams from my 2 post above ground rotary lift. I need to remove them to replace the seals because there leaking really bad. I found plenty of videos showing how to replace the seals but none on how to remove the ram from the carrier. Thanks so much for any information you can share. Manny :)
buckwheat_la
Lethbridge
No problem but there is a condition....you need to post shop/toolbox pics here on garage journal. You see some of us here are obsessed with tools and need a daily fix....lol
brownbagg
i got the same problem a benpak that been sitting for eight months with a busted seal because i cant figure out how to get the ram out
buckwheat_la
Lethbridge
Cut from thr pdf
Double “S” Formed Column Lifts.
Cylinder Removal Procedure
1) Loosen the equalizer cable on the opposite carriage.
2) Raise the lift to the top and rest the carriage on the top latch position.
3) Check to make sure the carriage is secure on latches.
4) Make sure the pressure has been relieved from the system.
5) Follow the proper LOCKOUT/TAGOUT procedures for disconnecting power to lift.
6) Remove the lower sheave cover at base of column.
7) With lowering valve depressed, manually pull cylinder down out of carriage.
8) Disconnect the swivel hose fitting at base of cylinder.
9) Cap hose ends and cylinder adapter to prevent fluid loss.
10) Carefully remove cylinder from column.
