who does a larger set of Hex Bit Sockets?
tommydog35
I am looking for a larger set of Hex bit sockets. When I say larger, I am looking for sizes 10mm - 22mm
It's expensive to buy them individually, does anyone have any recommendations for a nice quality set?
drtyler
Hazet has the 985 set. Short style, 1/2 inch drive, and includes 5, 6, 8, 10, 12, 14, 17, & 19mm sizes. If you want a 22 mm, you would have to add the 986-22 (regular length).
T
tommydog35
Thanks for your replies. I have a nice set up to 10mm, so only want sets over 10mm. does anyone do a set with anything bigger than 19mm?
48548
Phoenix
I think I have a proto that go up to at least 17mm.
J4900MA
T
tommydog35
thats a nice set. Does anyone do anything off the shelf with bigger sizes all in one set?
48548
Phoenix
Hell my father gave me both of these.... I figured he never used them. This one and the set above, I bought the snap on metal box to house them. The largest in here is a 5/8 I think.
shockwave
Marietta,ga
Look at hazet there 985 series is hard to beat keep in mind larger sizes jump and these are 1/2 drive
Vim impact 50 set covers a good range
I have snap on 4-14 and then jumps to 17,19 in 1/2 and 22mm in 3/4 from hazet
But honestly I have never used higher than 17mm on hex and 11mm/7/16 on mb calipers and 12,14 on euro drain plugs for differentials
SAATR
Sunnex makes a decent impact set. I have various loose sizes from 12mm to 17mm in 1/2" drive and 17mm, 19mm, 21mm, and 24mm in 3/4" drive. When the fasteners are that big, 1/2" drive often isn't enough.
Sent from my XT1585 using Tapatalk
Wes J
Peoria, IL
Remember that for regular socket head cap screws, the hex is smaller than the thread diameter. A 22mm hex socket would be for an M30 screw. You're not going to torque an M30 thread with a 1/2 drive tool.
14 and 17mm are common. I have a 12mm that I don't think I have ever used.
n8n
Curtis Bay, MD
J4900MA
My thought too. I had that set when I worked as a machine setup guy. Should have taken my whole box when I left and said keep my deposit, but I was way too poor to think about that at the time.
toolmutt
Texas
Advance Auto Parts currently has the Gearwrench 1/2" drive sets on sale for $19.99. I'm on my phone and can't make the link thing work.
Wes J
Peoria, IL
SK has a good set. It does skip a few sizes. But they do make those few sizes and sell them individually.
There are sizes that are almost never used. I work on machine tools that are 95% socket head caps screws. I've never needed a 12mm, 7/16, or 9/16.
Lot's of sets skip 9/64. If you use a lot of 8-32 screws you will want one.
cliftonbros89
Missouri
The SK set skips 9mm and doesn't include 19mm.
But it all depends on what you deal with. I've used both 7/16 and 9/16 several times.
hautpot
California
also snap-on has some low profile hex in several sizes.
shown here is 27mm in 1/2" square SHRM27.
PSYKO_Inc
Fairfield, CA
I've got a Duralast 1/2 drive set that has 12, 14, and 17 mm. I think it was around $18. I needed a 12mm for a transmission plug in a car I was fixing for a coworker, and knew that the trans plug in my truck was a 17, so I just bought the set instead of the individual sockets. I don't think I've ever used the 14.
T
tommydog35
thanks for all your replies. I have just confirmed and these are the sizes I need:
11mm, 12mm, 15mm, 16mm, 18mm, 22mm
I already have bits under 11mm, so there is no point buying a kit with sizes under this. For the sizes I want who offers a kit with best quality to price ratio?
T45
Those are odd-lot sizes in metric. Check a DIN chart--as mentioned earlier, the standard set is...
12-14-17-19 etc.
So You're really looking for a custom bundle or odd lot. Snap on and Apex industrial, for example, will make you a custom set, but you pay the price of the individual sockets in it. The upside is you don't pay for stuff you don't need so the cost on average evens out a bit (no pun intended).
n8n
Curtis Bay, MD
12-14-17-19 etc.
DIN is sadly obsolete it's now ISO or JIS depending on what you're working on.
I say sadly because I grew up working on cars with either SAE or DIN fasteners and it's hard to retrain my brain for the "new" head sizes. At least for regular hex head fasteners I always reach for 10, 13, 17, 19, 21 but those are no longer the "Standard" sizes.
Most of the stuff I worked on didn't have a lot of socket head cap screws so I never really learned the standards for those like I did for hex heads...
Wes J
Peoria, IL
I've never seen an 11, 15, 16, or 18mm hex. What are they used for?
T
tommydog35
Apart from Koken does anyone know who does a good quality 11mm hex bit? Snap-on do FAM11E but it's very long and I want a shorter bit. I have looked at hazet and stahlwille and neither do an 11mm bit.
bob15
Northeasten, CT
Buy the Snap On and cut it to the exact length you want. I find that a cut-off wheel works best, but a hacksaw or sawzall will also work fine.
T
tommydog35
Don't want to cut anything as it invalidates the warranty.
bob15
Northeasten, CT
The hex might not be covered. Or you could remove the "original warrantable bit" and install a "regular" hex bit cut to your size and you are done. Regular hex keys to cut are very cheap......
How often do you plan on replacing bits?
T45
The new bit is $10 and doesn't invalidate the warranty on the socket anyway. You're not gonna crack the socket. If your bit gets messed up you just put a new one in. They make stubby bits in 3-10mm and use the same socket base for long and short cersions, so you can just swap em out if you need to, just gate the 'e' version not ones with set screw.. They also have 207FHRM, a low profile hex set of sockets, but the skip from 10 to 12mm.
dede2897234
Northern, Ohio
tommydog35,
Vim Tools makes a stubby, 1/2" drive, 10 piece metric (6-8mm; 10-14mm; 17, 19mm), impact hex set. The model# is IMPACT-VM6. The set is made in Taiwan. I bought it last year from an independent industrial tool supplier for $40. Here are some pictures from this set: LINK.
Dave
T
tommydog35
tommydog35,
Dave
How do you find those bits as the price is very cheap? Are they better than something like Sunex 2639?
Strouty
Southern Maine
VIM are very good quality, pretty sure they get rebranded by bigger names too. I would not hesitate to buy them, they also offer stubby lengths.
bob15
Northeasten, CT
He could even buy this Eklind 11mm key from Zoro and cut it to any length desired. And it is a whopping $ 1.81. It works much easier than trying to get a free replacement. And yes, I have done it many times at work, even with my Snappy hex sockets. https://www.zoro.com/eklind-hex-key-tip-size-11mm-16522/i/G4395912/
