Can someone tell me how thick these 2 usually are? Thanks
W weatherby460 Well-known member Joined Mar 13, 2015 Messages 425 Location Southern WI Jul 17, 2016 #1 Can someone tell me how thick these 2 usually are? Thanks
J justinjoyal Well-known member Joined Apr 30, 2015 Messages 888 Location Quebec Jul 17, 2016 #2 You can figure roughly R3.5 per inch, so about 15in for R52 and 18" for R62.
OP W weatherby460 Well-known member Joined Mar 13, 2015 Messages 425 Location Southern WI Jul 17, 2016 #3 Any negatives of getting the r62 besides the cost?
J justinjoyal Well-known member Joined Apr 30, 2015 Messages 888 Location Quebec Jul 17, 2016 #4 No. Just more $$$ on the spot.
J jkeyser14 Well-known member Joined Dec 19, 2008 Messages 1,822 Location (rural) Maryland Jul 17, 2016 #5 weatherby460 said: Any negatives of getting the r62 besides the cost? Click to expand... Depending on the truss spacing and how thick the drywall is, I have heard of the added insulation weight causing some sagging. See here: http://www.garagejournal.com/forum/showthread.php?t=15992
J justinjoyal Well-known member Joined Apr 30, 2015 Messages 888 Location Quebec Jul 18, 2016 #6 Shouldnt sag if built properly. Or use 5/8 drywall if worried.
M Milton Shaw Well-known member Joined Feb 11, 2011 Messages 4,856 Jul 18, 2016 #7 Don't wet the bottom side of the drywall to much. I used popcorn spray on my ceiling and it sagged between joists. Should have painted it and then sprayed popcorn to keep more of the water out of the surface of the drywall.
OP W weatherby460 Well-known member Joined Mar 13, 2015 Messages 425 Location Southern WI Jul 18, 2016 #8 No drywall...I used steel panels.
