pendragon1998
I'm driving out later today to inspect a Craftsman 150 pedestal drill press. Can y'all give me any tips for inspecting it and them moving it if I buy it? I'm going to have to lay it down in the back of my 4runner and drive it for 2.5 hrs so I don't want it to crack under it's own weight.
Things I was planning on checking for:
What else?
- Cracked castings.
- Listen to the bearings when it runs.
- Return spring on quill.
- Use a square to check for vertical square against the table on a bit chucked in the quill.
- Drill a hole with a good bit, then compare the bit to the hole to check for runout.
- Drill into some wood with just the tip at full extension to look for runout.
- I don't have a dial indicator, but I was planning on chucking in a straight round rod or drill bit and turning by hand against a block of wood to see if I could visually assess any runout.
What else?
